Finisher sr 3090 on mp4200: Dog ear whit jam when gate deviate to basculate tray
  • luca72
    • Oct 2017
    • 1778
    damn this is the week of the finisher, I must say that rarely have given me problems, but now it is jump out of this.
    it does 1 time about every 80-100 sheets: the paper during the gate click that sends the paper down for the basculating tray strikes somewhere on one side producing dog ears and lock it , visually everything seems ok, I removed the rear cover and it looks like everything ok, my suspect falls on lazy descent gate activation solenoid (?) deformed top cover (containing the gate), low solenoid power supply, board that is going to fail (I would exclude it) ... if the mechanism is not activated, if I do get out the paper from the upper tray it works fine .. anyone knows this problem, or has any suggestions to give me ...tomorrow i bring it here in lab so i check it better.
    excuse me, i was wrong to write a title, i just got back tired from work: its a mp4002 not 4200..how i do correct the title?
    "I'll be back"
  • mikadonovan
    • May 2008
    • 2931
    Re: Finisher sr 3090 on mp4200: Dog ear whit jam when gate deviate to basculate tray
    Well, you can obviously see what and where it's dog-earing. Check that part of the paper path for burrs on plastic guides or paper clips, or staples. If a solenoid is dropping out it would damage more than just one edge of the paper.
    NEVER ASSUME ANYTHING
    • fshead
      • 2376
      i double that>>paper clips, or staples.
      Most of my issue on ricoh sorter are usually because of customers using the sorter top as a work table and then
      just leaving staples,paper clips to fall inside,,,
      I usually pull sorter and shake it on its side lightly and see what i can find..
      Guide burrs too if its a very used sorter and sometimes there are small plastic guide tabs that might come loose.
      • Dan G
        • Nov 2014
        • 56
        i would think Bridge unit or finisher entrance guide area
        I have had the mylar on the bridge exit cause similar issues
        • luca72
          • Oct 2017
          • 1778
          thank you all for the support guys, this morning a colleague went because I had another urgent intervention.
          since the mc we sold it used a week ago, did not have the finisher, and I mounted it, it seems that I forgot to put the two gadgets-guide on the fuser output, I have to tell the truth, it seems strange (?) , why would he have to jam even in the upper tray at this point, boh? we'll see .... thanks again, see you next time
          "I'll be back"
