scan to gmail settings Ricoh mpc3003
  • ThePomqueteer
    • Sep 2016
    • 73
    #31
    1. Go to your Google Account
    Cheers
    Pomqueteer
    • sandmanmac
      • 3990
      #32
      Re: scan to gmail settings Ricoh mpc3003
      Originally posted by Selinwine
      Have you tried simply disabling two-step authentication? Since the main problem is two-step authentication, there should be no problems or errors without it. Although there is always another option, you can change the phone from your account to a temporary phone from such a service quackr.io after that, you will need to write a small algorithm so that the fax or printer automatically takes the code from the source. I'm not sure of course that such a thing can be implemented at all, but with the right desire, I'm sure everything can be done. My friend, for example, out of boredom, completely disassembled and reprogrammed a smart vacuum cleaner. From which he managed to make a good AI interlocutor with whom you can have a very pleasant chat.
      1: Read the entire thread
      2: the thread is over 2 years old, so I think a safe assumption would be that the issue is sorted
      3: Simply disabling 2FA is NOT the solution, because "use less secure apps" at a minimum would then need to be turned on....as discussed earlier
