scan to gmail settings Ricoh mpc3003
  • Mark Bbb
    • Jun 2012
    • 1662
    We can receive and send mails from the gmail account...
    The firmware is updated.
    But in the google account
    the mpc3003 needs a password with the "Two step verification" (in my google account that comes with verification code), but it is not clear to me which precise setting we much choose that will gives us this password. So, that is the problem.
    I have put "access for less secured apps" in the Google account to "on" (that was easy)
    Can you help?
    Machine settings are all set well (i guess?):
  • skinnyb
    • Jul 2008
    • 291
    Re: scan to gmail settings Ricoh mpc3003
    Right below the smtp server is a switch to turn on SSL. This must be on, just changing port to 465 doesn't work. All other settings sound OK
    Sent from my LM-V405 using Tapatalk
    • mincopier
      • Dec 2015
      • 289
      This is machine is not capable of "Two Step verification". This needs to be disabled in the account.
      "Use Less Secure Apps" also needs to be enabled. If this cannot be done on this account for security reasons setup an account specifically for the machine.
      I also prefer to use port 587 instead of 465.
      On occasion you have to confirm a security alert the first time an email is sent from the copier. Sometimes after creating the account Google detects the copier as trying to improperly use that email account. Just approve it and all will be fine.
      • Mark Bbb
        • Jun 2012
        • 1662
        forgotten to mention, yes, this setting is on
        • skinnyb
          • Jul 2008
          • 291
          I second the post above. 2 step must be disabled as well as allow less secure apps on. I usually setup a "dummy" Gmail account for scanning purposes only so the customer real account can stay as secure as possible.
          • guitar9199
            • Sep 2016
            • 1100
            Can you help?
            Allow Less Secure Apps- Turn on.
            2-Step Verification- Turn off.
              • 37653
              But in the google account the mpc3003 needs a password with the "Two step verification" (in my google account that comes with verification code), but it is not clear to me which precise setting we much choose that will gives us this password.
              "Two step verification" has to do with logging in to the account from as computer. To change it, access your account and click on the gear symbol and select Settings. Select Other Google Account Settings under Accounts and Import. Select Security.
              • copier tech
                • 8237
                Once you've sent a test scan what error does the machine show?
                Try turning on DHCP let the machine pull all the network details & try another scan then add 8.8.8.8 as a secondary DNS server.
                The first time you set this up scanning will fail every time until you have logged into that gmail account & set the MPC3003 as a safe sender.
                You should get an email asking "did you log in to this account on this IP address" etc you need to confirm this or it will never scan.
                • luca72
                  • Oct 2017
                  • 1792
                  Can you help?
                  try to send an email and let it go in error, check the system registry in WIM, you will find your failed attempt with date, time, etc, with the exact error message specified, then apply the appropriate changes in the settings.
                  if there are errors like: 000xfabd..bla..bla..bla, or other strange server response... copy and paste on google and you will find immediately.
                  "I'll be back"
                  • Mark Bbb
                    • Jun 2012
                    • 1662
                    Dear Copier Tech,
                    The DNS 8.8.8.8 was already set. I will follow your procedure, but how do i put mpc3003 as a safe sender in the gmail account?
                    Thanks for your help
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      After scanning to the gmail address on this mpc3003, and checking WIM, there is no error message at all in WIM.
                      I guess i thanked you to quick...
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Dear Copier Tech,
                        OK, got it!!!
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          We have made a account for this mpc3003 in google with an new gmail address (and passort) and programmed this info in the WIM mpc3003.
                          We have put off the "access for less safe..." & "authentication in 2 steps"
                          We Use port 587
                          Still not working...
                          Perhaps this new gmail address must be marked as safe in the new google account?
                          • Mark Bbb
                            • Jun 2012
                            • 1662
                            Sorry, i can be an @ss from time to time
                              • 37653
                              When trying to scan to gmail or G Suite, read and follow the instructions from Google Support.
                              Send email from a printer, scanner, or app - G Suite Admin Help
