MP 4055 SPDF 3100 Error
  • bdesire
    • Oct 2012
    • 62
    Hello All, I have a DF3100 with a paper curl at the exit problem, of course it never happens while the technician is there but I'm told the paper will curl and sometimes completely flip over after exiting the feeder. Has anyone seen this? is there a modification for the exit section or a static eliminator for this section? Thanks in advance.
    Re: MP 4055 SPDF 3100 Error
    is it humid in the location?
    what paper are you using?
    what are the paper tray settings?
    what gsm paper are you using?
    what supplies are you using?
    what are the total counts on unit?
    how many pages on fuser?
    is the paper DAMP?
    so many Q's
    so little info!
    PhilB the "Dentist"
    • Oze
      Ricoh Fanboy
      • Jul 2008
      • 1663
      You pull those teeth Phil..!!!
        I'm trying Brother.. believe me!
        • davel
          • Oct 2011
          • 1109
          I got the impression that the issue is curling in the SPDF, sounds like the originals are curled before feeding.
          • GIUBOSS
            • 1437
            sometimes it may happen that the rear corner to the left of the ADF does not come into contact with the machine due to the spring of the unloaded hinge. Or something more banal like a paper clip. (sorry for imperfect English).
            • bdesire
              • Oct 2012
              • 62
              Yes, sometimes the originals are taken directly from a desktop printer and fed through the feeder, other times it will be a mixture of files from a folder and freshly printed originals. The client is trying to save on machine clicks on the 4055 by printing to a desktop printer and then manually faxing the print job.
              • bdesire
                • Oct 2012
                • 62
                I will check that out, Thanks for the info.
                • davel
                  • Oct 2011
                  • 1109
                  Why not print to the fax driver.
                  • Gary Bowen
                    Bowdog
                    • Mar 2008
                    • 250
                    You are far too accommodating with your customers. The last time I had a Feeder problem similar to this a tech had already done a preliminary call. When I went in I made sure I had a sample set of the originals the customer was complaining about to test for myself. The "originals" were in in very poor condition (curled to begin with, staple holes, and some with post it notes permanently attached). I wasn't sure if the customer even knew what a ARDF was for. Anyway, given the condition of the originals they were happy with my work. (I was going to say they were happy when I left but that could be taken the wrong way).
                    Do check out GIUBOSS' suggestion.
                    • KenB
                      Geek Extraordinaire
                      • Dec 2007
                      • 3944
                      Originally posted by Gary Bowen
                      I was going to say they were happy when I left but that could be taken the wrong way.
