please help me : how soft were this model mp 6001 and flash file
code mp 6001 sc878
Re: code mp 6001 sc878
try to Initialize the address book data in SP5-846-050 and the user SP5-832-006. If you can also check or format the hard disk, update the firmware (if you are a technician), last resort replace the controller. -
I know that but there is no agent for Ricoh Company in Sudan. I found the software files but they are password protectedComment
You might try Ricoh Middle East | Ricoh Middle East or Ricoh South Africa Office solutions - Audiovisual Equipment - Production Printing - Managed Document Services - IT Services | Ricoh South Africa | | Ricoh South Africa.Comment
When the machine is ready after boot if the operator turns it off from the main switch
without pressing the auto-off button on the keyboard (right side) the NAND flash
memory on the controller could be damaged and originate the code SC878.Comment
Before turning off the machine from the main switch, make sure that the
operating button is not lit or flashing. If the machine is turned off
from the main switch while the LED is on or flashing it could
damage the hard disk or flash memory.Comment
