code mp 6001 sc878
  • fidyas
    • Dec 2019
    • 6
    code mp 6001 sc878
    please help me : how soft were this model mp 6001 and flash file
  • GIUBOSS
    • 1385
    Re: code mp 6001 sc878
    try to Initialize the address book data in SP5-846-050 and the user SP5-832-006. If you can also check or format the hard disk, update the firmware (if you are a technician), last resort replace the controller.
    • fidyas
      • Dec 2019
      • 6
      The machine was working but you gave me a message after the reboot I restarted and before it finished I got it started
      • Brianneoe
        • May 2015
        • 318
        That code is listed as a "TPM electronic authentication error". Two fixes listed in the Goose's Guide.
        1-reload firmware
        2- replace controler
        Good luck
        • fidyas
          • Dec 2019
          • 6
          1-reload firmware
          Good luck
          need firmware file
            • 37048
            Originally posted by fidyas
            need firmware file
            Forum General Rule 5. Discussion of illegal activities such as software and music piracy and other intellectual property violations are not allowed.
            Ricoh firmware is considered intellectual property.
            • fidyas
              • Dec 2019
              • 6
              I know that but there is no agent for Ricoh Company in Sudan. I found the software files but they are password protected
                • 37048
                You might try Ricoh Middle East | Ricoh Middle East or Ricoh South Africa Office solutions - Audiovisual Equipment - Production Printing - Managed Document Services - IT Services | Ricoh South Africa | | Ricoh South Africa.
                • anothertech
                  • 1757
                  Order a Controller PCB
                  • GIUBOSS
                    • 1385
                    When the machine is ready after boot if the operator turns it off from the main switch
                    without pressing the auto-off button on the keyboard (right side) the NAND flash
                    memory on the controller could be damaged and originate the code SC878.
                    • GIUBOSS
                      • 1385
                      Before turning off the machine from the main switch, make sure that the
                      operating button is not lit or flashing. If the machine is turned off
                      from the main switch while the LED is on or flashing it could
                      damage the hard disk or flash memory.
                        • 37048
                        Then the question becomes what happens if there is a sudden power outage?
                        • fidyas
                          • Dec 2019
                          • 6
                          Control is very expensive in my country. If you want to help me, give me the software file, this is what I need
