MP C5502 Smurge copy
  • Manikandan T
    • Sep 2019
    • 14
    hello i had smurge copy issue in customer place i change fuser unit recently form 4502 in used machine but i have same issue but i checked the fuser with another 4502 machine its working good any suggestions???? is there any setting in service mode
  • 8T2
    • Aug 2015
    • 257
    Re: MP C5502 Smurge copy
    Looks like the black drum but the supplied photo not very clear on my side
    Sent from my WAS-LX1 using Tapatalk
    • Manikandan T
      • Sep 2019
      • 14
      i checked black drum unit on c4502 its good
      • davel
        • Oct 2011
        • 1107
        How do test prints look, is it only on black, how is colour print, what are the PM counts.
        • Manikandan T
          • Sep 2019
          • 14
          Test print is ok
          If I make single single copy is good if I make continue copy the problem will come
            i would like to ask.. if I don't tell users to PM... then please don't take it upon yourself to PM me ... esp IF I don't comment on your problem.
              • 37533
              Exactly how did you check the drum unit? From the image you attached it looks to me like the charge roller is dirty.
              • copier tech
                • 8174
                Fitting used parts you'll be going round in circles.
                Fit a new fuser sleeve & pressure roller.
                • Manikandan T
                  • Sep 2019
                  • 14
                  I place drum unit in 4502 the copy quality is good
                  • anothertech
                    • 1771
                    You might want to check the ITB cleaning unit.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      Also check the DeSmurge unit is operating correctly..!!!
                      • Manikandan T
                        • Sep 2019
                        • 14
                        What is DeSmurge unit?
                        Where I find in machine?
                        • ABS tect
                          • Sep 2013
                          • 511
                          Your photo is a little hard to see but it looks to me like either you are printing on thick paper without the correct settings so after 1 copy you are getting a ghost image on the next page because of the fuser. If you're using thick paper i like to set it to Thick 2 and print from the bypass.
                          If your paper settings are fine and its just regular 20lb plain paper, and your fuser and drum are fine, then you most likely have a bad DV unit and your toner is not adhering properly and is going to the next page.
                          • mikadonovan
                            • May 2008
                            • 2931
                            It's a joke, Dude. You misspelled "smudge" in the title of the thread.
                            NEVER ASSUME ANYTHING
                            • FrohnB
                              • Jul 2017
                              • 1919
                              Omertà
