WARNING for MP 4002/5002 System f/w update.
  • FrohnB
    • Jul 2017
    • 1919
    WARNING:
    We have been running into SC878 codes after updating to latest System firmware (and second latest) V2.22 & V2.23 for the MP4002/5002.
    According to Ricoh's bulletins, the only way to fix this is by replacing the controller. They say you won't be able to access svc mode or do f/w update once the code appears. Do not believe it!
    We have actually been able to reboot machines and downgrade the system firmware to 2.21 or 2.20. When it boots, it will beep and the red wrench will appear, but still allows us to load firmware.
    Haven't really had a need to update these machines (no fixes for anything major), but did on a few in the past week or so with same results.
    It also fucks up the @remote registration, so you have to get it removed from Center Server and Re-register with a new number.
    Omertà
    Re: WARNING for MP 4002/5002 System f/w update.
    Originally posted by FrohnB
    WARNING:
    great info!
    Thanks for the update!
    • copier tech
      • 8238
      WARNING:
      Thanks for the warning.
      Looks like this was addressed with v2.24 released on the 21st Jan.
      D1295760F [Version] 2.24.pdf
      • FrohnB
        • Jul 2017
        • 1919
        Omertà
        • mandriva_linuxx
          • Nov 2020
          • 2
          please can you help me
          i need to know how you were able to reboot machines and downgrade the system firmware to 2.21.
          thanks
          • Oze
            Ricoh Fanboy
            • Jul 2008
            • 1663
            thanks
            Do you know HOW to update firmware via SD card?
            • copier tech
              • 8238
              thanks
              System/copy firmware latest is now Ver.2.24 so simply upgrade to this version.
              Firmware Update - Printer & Copier Firmware
              • mandriva_linuxx
                • Nov 2020
                • 2
                Thanks for your reply, i tried using memory card 512mb ,but that didnt work.
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  oh my... i did an update yesterday!
                  • Julio Yap
                    • Sep 2024
                    • 3
                    Hi, I need the firmware for the Ricoh MP 5002, please, who has it?
                    • Julio Yap
                      • Sep 2024
                      • 3
                      • Julio Yap
                        • Sep 2024
                        • 3
                        Hi, I need the firmware for the Ricoh MP 5002, please.
                        • GIUBOSS
                          • 1437
                          Contact the technicians privately for the fw instead of posting 3 times on old threads or start a new one.
                            • 37653
                            If you keep digging up posts that are nearly 4 years old, dead and buried you night not get much help, grave robber.
                            • copier tech
                              • 8238
                              Happy to help, drop us an email.
                              www.printerfirmware.co.uk
