C/Q and errors related to mpc3003/4 to 6003/4 metis series
  • mga
    Copier Technician
    • Dec 2010
    • 1393
    [Misc] C/Q and errors related to mpc3003/4 to 6003/4 metis series
    Hello gents ricoh technical are getting reports of this.
    If you find you have issues with colour alignment and random error codes after fitting the ITB belt D1776098 please try sourcing D1496097 (the older number
    Regards Mark
  • emiliorsg
    • Jul 2018
    • 141
    Re: C/Q and errors related to mpc3003/4 to 6003/4 metis series
    I had problems with alignment before replace a ITB belt in a c2503 and it was solved with a ITB belt of a used machine.
    • TonerMunkeh
      Professional Moron
      • 3865
      D2416097 is the latest part number.
      Hit it.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Hi ricoh are saying this problem only happens when ordering new D1776098 all other part numbers should be ok that info was only posted last week on ricoh technical UK just passing the information on.
        Regards Mark
        • Mark Bbb
          • Jun 2012
          • 1662
          Great trouble here to:
          mpc3004 registration problems...
          Seems that Ricoh had given the wronge number for the ITB belt AND the cl unit.
          I have replaced only the ITB cl unit on a c3004 (ricoh told me to use the imc3000 cl unit D0BQ6141);
          2 months later the original ITB belt on this machine was riped.
          So, i ordered a new belt, and ricoh says to use D1776089.
          But that doesn't fit at all, it is to width.
          So tommorrow i need to go back and put the whright parts in it!
          Hopfully the drums did not get damaged.
          • Mark Bbb
            • Jun 2012
            • 1662
            The correct part of the mpc3004 ITB belt = D2416097
              • 8119
              • Mark Bbb
                • Jun 2012
                • 1662
                I think that is very wise.
                Because this belt is not so flexible at all, the least push will end up in a dent...
                And also there is not much space for the belt to pull it over the ass'y.
                And when you do, you need to be carrefull that it is located exactly between 2 plates, that means, before you even know it, its damaged!
                  • 8119
                  Also the secret is to thoroughly clean the ITB unit drive rollers before you slide on the new belt. Even a light dusting of toner will cause the belt to slip very slightly causing colour mis reg issues.
                  • luca72
                    • Oct 2017
                    • 1708
                    for now I have only changed two, and I have not had any problems, what problems does it have? slide on the rollers?
                    • Mark Bbb
                      • Jun 2012
                      • 1662
                      What was the ITB belt part number you have used?
