Mp5002 smudges
  • mrfuser
    • 1622
    Mp5002 smudges
    Client is getting smudges all over page. Especially first thing in the morning it is the worst. Replaced drum, blade, transfer assembly and developer is not very old. Any ideas?
  • GIUBOSS
    • 1436
    Re: Mp5002 smudges
    damp paper, if you leave the paper in the first drawer install a heater, all the original materials toner, fusing?
    • FrohnB
      • Jul 2017
      • 1919
      Re: Mp5002 smudges
      A bigger picture of the sample would help.
      Have seen the drums get a weird "buil-up" on them that can be cleaned off.
      Toner recycling section in Drum unit can get "full" and dump waste/ recycled toner on drum during first few prints.
      You say developer not that old, but you could try swapping dev unit, just to be sure. Make sure you clean magnetic roller in dev. unit. (gets a black coating on it. Scotchbrite it until it's silver again.
      Fuser guides clean?
      Fuser Rollers clean?
      Omertà
        • 37533
        Re: Mp5002 smudges
        There are numerous threads about quality issues on the 35/45 and 40/50 ppm model caused by filming building up on the development roller. I noticed that you did not mention the charge roller and charge cleaning brush roller. Were they replaced at the same time as the drum? If not, why not?
        For some reason I hve a feeling that the 5002 is not using Genuine Ricoh toner and developer.
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          Re: Mp5002 smudges
          [ATTACH=CONFIG]45123[/ATTACH]
          Better samples would be a help
          Regards Mark
            Re: Mp5002 smudges
            people need to stop uploading .jpg samples..
            we ALL prefer .pdf samples.
            • mrfuser
              • 1622
              Re: Mp5002 smudges
              Ok I will try later to get better samples. Yes I scrubbed dv roller and replaced charge roller. Yes it is genuine Ricoh supplies
              • Dan G
                • Nov 2014
                • 56
                Re: Mp5002 smudges
                happening first copy its more likely a fuser issue not warming up properly
                  • 37533
                  Re: Mp5002 smudges
                  Or the charge roller not reaching full potential.
                  • FrohnB
                    • Jul 2017
                    • 1919
                    completely . Dev. unit, PCU, transfer, fuser. If those are all good, then someone just has dirty fingers.
                    Omertà
                    • mrfuser
                      • 1622
                      • MIGUELMARCHENA
                        • Feb 2018
                        • 195
                        Re: Mp5002 smudges
                        Not having a clear image, it is a bit difficult to determine what it is.
                        I dare to say, according to what you have written, that the problem is in the mornings
                        Is the environment cold?
                        Many times in cold rooms, first impressions appear like this, with spots, as it does not melt well, although this new fuser etc.
                        increase the initial warm-up time
                        1103001 to 1
                        and that's it
                        1102002 as you deem necessary and also the 1103003
                        Cheers
                        • farhad
                          • Apr 2020
                          • 40
                          Re: Mp5002 smudges
                          change transfer belts blade and and drum unit seal blade
                          • fshead
                            • 2376
                            Re: Mp5002 smudges
                            Re: Mp5002 smudges
