Gestetner MP2501 - Error code SC554-00
  • francura95
    • Feb 2020
    • 7
    [Error Code] Gestetner MP2501 - Error code SC554-00
    Hello guys,
    while using my printer I received error code sc554-00.
    Do you know what it refers to and how can I solve it?
    Is it possible to solve with the reset of the printer?
    Thank youWhatsApp Image 2020-03-02 at 18.02.47.jpgWhatsApp Image 2020-03-02 at 18.02.47.jpg
  • FrohnB
    • Jul 2017
    • 1919
    Re: Gestetner MP2501 - Error code SC554-00
    Originally posted by francura95
    Hello guys,
    Thank you[ATTACH=CONFIG]45124[/ATTACH][ATTACH=CONFIG]45124[/ATTACH]
    Something wrong with your fusing unit.
    You'll need someone to figure out why the fuser is throwing the code, and to get into service mode to reset the code.
    Omertà
      • 37618
      Have you ever tried looking in the service manual?
      Better yet, since you appear to be an end user, call an authorized Ricoh trained tech.
      • francura95
        • Feb 2020
        • 7
        I reset the error on the printer and in the right compartment I found this piece in these conditions. What can it be due to? and what is this piece?WhatsApp Image 2020-03-02 at 19.29.04.jpg
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          I reset the error on the printer and in the right compartment I found this piece in these conditions. What can it be due to? and what is this piece?[ATTACH=CONFIG]45127[/ATTACH]
          Call a ricoh Service engineer rebuild fuser
          Regards Mark
            • 37618
            Again I say hire someone who knows what they are doing.
            • francura95
              • Feb 2020
              • 7
              there are no technicians in my area. I just wanted to know what it is
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                OK looks like fuser over heated you will have to replace hot roller & pressure roller and bearings and thermistors & cleaning roller & pawls good luck
                Regards Mark
                  can you please upload PDF's of the problem.. what is that orange strip on top of fixing unit? did someone forget to remove tape? It LOOKS like part of the fuser roller/belt.
                  • copier tech
                    • 8212
                    Hello guys,
                    From your picture I can see the coating has peeled off the pressure roller. This will need to be replaced along with the hot roller & thermisters.
                      • 37618
                      Considering the lack of training and experience it might be better to replace the entire fusing unit. Initial problem may have been a shorted triac on the PSU or a problem with the BICU(if he had a service manual he would have known that). In either case it will blow the new fusing unit if not fixed. See if you can buy an operational used MP2501 for use as a parts machine. Might be less expensive than a BICU.
                      • GIUBOSS
                        • 1437
                        if you don't find better try here
                        iStudio – Partner Ricoh Matera
                        • Gab
                          • Aug 2015
                          • 676
                          You need to replace at least press roller, because its coating damaged.
                          If the problem is overheatting you must replace thermistors and thermostats too.
                          Try to find what caused this damage.
                          As i can see you remover fuser unit from machine so send it to a Ricoh technician to do alla the job
