Ricoh mp c5503
  • heath03
    • Jul 2018
    • 80
    Ricoh mp c5503
    using the document feeder the top copies are coming out lighter than the second side when printed. is there something that would be causing this. maybe need to clean the doc feeder.
    ty you in advance
    Heath
  • fshead
    • 2376
    Re: Ricoh mp c5503
    ty you in advance
    Heath
    MOIST PAPER..if 1st side is lite and duplex side is darker
    open a new ream
    • heath03
      • Jul 2018
      • 80
      Re: Ricoh mp c5503
      i did that, the job started out good. a little lite on front side, but backs are good. just installed a new ricoh developer today
      see pictures
        • 37550
        Re: Ricoh mp c5503
        see pictures
        New developer or new development unit? To my knowledge Ricoh does not sell just developer. Your samples look like either a dirty laser shield glass or dirty doctor blade.
        • davel
          • Oct 2011
          • 1107
          Re: Ricoh mp c5503
          Have you cleaned optics? If not should be first step for copying issues.
          • heath03
            • Jul 2018
            • 80
            Re: Ricoh mp c5503
            its a ricoh new unit. i have cleaned laser shield. maybe dr blade could be it
            ty for tips
            • copier tech
              • 8187
              Re: Ricoh mp c5503
              ty for tips
              What is a "new unit?"
              Does this machine have a single pass DF?
              Does the issue only happen when using the DF?
              What do the internal test prints look like on all colours?
              • heath03
                • Jul 2018
                • 80
                Re: Ricoh mp c5503
                it only happens doc feeder, must be optics cleaning needed. prints perfect from thumb drive and from computer
                ty for the help
                • davel
                  • Oct 2011
                  • 1107
                  Re: Ricoh mp c5503
                  ty for tips
                  Can not be new, and no none of those, if test prints are good, engine is good.
                  • copier tech
                    • 8187
                    Re: Ricoh mp c5503
                    ty for the help
                    • heath03
                      • Jul 2018
                      • 80
                      Re: Ricoh mp c5503
                      yes sir, single pass DF. i was wrong. it is doing it from the thumb drive as well. see picture. start doing it at around 100 copies
                        • 37550
                        Re: Ricoh mp c5503
                        ty for tips
                        Guess again boy child. The model was introduced in July 2013.
                        Now properly clean all the optics and run Auto Color Calibration in User Tools. Generally speaking that takes care of about 99% of light image problems.
                        • copier tech
                          • 8187
                          Re: Ricoh mp c5503
                          Help us to help you.
                          Enter SP mode & print a sample of each colour & post it here.
                          SP2-109 etc
                            • 37550
                            Re: Ricoh mp c5503
                            Still looks like a dirty laser shield glasses or doctor blades.
                            • heath03
                              • Jul 2018
                              • 80
                              Re: Ricoh mp c5503
                              yes, i can run around 100 copies and then black is dropping out, ill stop clean laser shield and back to normal. what keeps making the laser shield dirty that quick in your opinion.
                              ty for the info sir
