Ricoh mp c5503
    • 37491
    #16
    Re: Ricoh mp c5503
    Originally posted by heath03
    yes, i can run around 100 copies and then black is dropping out, ill stop clean laser shield and back to normal. what keeps making the laser shield dirty that quick in your opinion.
    ty for the info sir
    Most likely a development unit, PCU or both in need of replacement.
      Re: Ricoh mp c5503
      yes sir, single pass DF. i was wrong. it is doing it from the thumb drive as well. see picture. start doing it at around 100 copies
      why the HELL can't people upload samples in PDF format? It's been suggested time n time again.
      JPG's do not give us an actual representation of the problem, and are too hard to explode for closer inspection.
      and this isn't a 'new' product.
      • heath03
        • Jul 2018
        • 80
        #18
        Re: Ricoh mp c5503
        72 dpi pdf RGB and Jpeg RGB is the same by the way, only using for viewing, both are compressed bc the site will not allow you to upload a high res file. we have heidelberg printing equipment 8 color.
        thank you for your help tho
          Re: Ricoh mp c5503
          Hell even faxesvcan ve set at 200-300dpj.
          I have have uploaded larger that 300dpi. :-(
          • heath03
            • Jul 2018
            • 80
            #20
            Re: Ricoh mp c5503
            its still compressed, it would be to large to upload here. we print in 5000 dpi whole different ballgame
            • davel
              • Oct 2011
              • 1104
              #21
                • 37491
                #22
                Re: Ricoh mp c5503
                You should be able to scan to folder, email or a memory storage device, thumb drive or SD card, as single page pdf or even tif.
                  • 37491
                  #23
                  Re: Ricoh mp c5503
                  Stop trying to blow smoke out your ass. Maximum print resolution for the MP C5503 is 1200X1200 dpi.
                  You are getting real close to starting to collect Red cards.
                    • 37491
                    #24
                    Re: Ricoh mp c5503
                    Seeing as you are an end use, contact your nearest Ricoh authorized dealer and pay to have an experienced tech come look at your machine.
                    • anothertech
                      • 1770
                      #25
                      Re: Ricoh mp c5503
                      I'll do it, where's the machine?
                        • 37491
                        #26
                        Re: Ricoh mp c5503
                        His profile say powhatan. Possible Powhatan, VA.
                        • heath03
                          • Jul 2018
                          • 80
                          #27
                          Re: Ricoh mp c5503
                          i scanned the document to a thumb drive all pages are the same in density and darkness, from page to page its dark to a gray.
                          any ides ty for input
                          • fshead
                            • 2376
                            #28
                            Re: Ricoh mp c5503
                            Any ides ty for input
                            better call saul.............saw some fractural delineation for clarifacation
                            • FrohnB
                              • Jul 2017
                              • 1919
                              #29
                              Re: Ricoh mp c5503
                              We have seen on the Cxx03 and Cxx04 series, that a bad PCU can cause this issue.
                              Just had one that came in from wholesaler with low meters (black = 60k, Color = 20k), internal prints are perfect, but anything run through DF would be really washed out and light. Replaced black PCU and Presto! Back to nice dark copies.
                              Also, check on the back of your black PCDU, and make sure the cover with the little copper contact inside is attached (and completely screwed down), have seen these left off quite a bit, but usually ALL prints/ copies come out bad.
                              Otherwise, back to basics, like cleaning optics. With the single pass feeders, the CIS scans back side of page, and the "regular optics" scan the front simultaneously. If backside is fine, then I would be looking at regular optics or Doc. Feeder glass.
                              Omertà
                              • heath03
                                • Jul 2018
                                • 80
                                #30
                                Re: Ricoh mp c5503
                                that you sir for the info and feedback
