Ricoh Pro C5100S PCU/No Lubricant Error
  • printczar
    • Aug 2025
    I'm new here. Fairly new to my Savin/Ricoh Pro C5100S. I got an error that said "No lubricant. Replace Cleaning Unit for Photoconductor Unit."
    I purchased a new coating bar and PCU Cleaning unit. I can't seem to fing any guidance on where the coating bar is located and what I need to do.
    Any help would be appreciated.
    Thanks!
    • 37556
    Re: Ricoh Pro C5100S PCU/No Lubricant Error
    I would not advise trying to work on a Production color machine if you are not trained or at least have a service manual and experience with Ricoh color MFP.
    • Zaxxon
      • 608
      Lub bar are inside the pcu cl. unit. take some skills to work on this model, agree with Slimslob.
      Please start you post with brand, model, problem.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        Thanks!
        Wow call a engineer the lub bar is in the cleaning unit
        Regards Mark
          a novice SHOULD NEVER attempt this.
          • dalewb74
            • Feb 2018
            • 1162
            though i haven't worked on the pro 5100, i have worked on the pro 5200. and i totally agree with what everyone else has said. this really is something that should be worked on by a trained ricoh tech. i spent a week in training on this model. and from my experience the drum cleaning unit, as you described, is one of the parts i replace the most often.
            • Zaxxon
              • 608
              • anothertech
                • 1771
                Hardest fuser rebuild known to man.
                • copier tech
                  • 8192
                  Thanks!
                  "fairly new" or a complete novice?
                  Its all in the service manual.
                  • dalewb74
                    • Feb 2018
                    • 1162
                    yeah the pro5200 i spent a week rebuilding that fuser. between trying to take care of my other calls and the rebuild. oh my goodness what a chore. and whatever you do don't mix up the screws, bad bad baddddddd. that was the biggest thing they emphasized in training, don't not put the screws in the wrong location. 11 different screw types on one stinking fuser.... you would think all the years in business they could come up with easier rebuilds for any of the parts on these machines.
                    • skinnyb
                      • Jul 2008
                      • 291
                      Truth... The newest one (Pro 5300/ IM C6500) they significantly simplified the Fuser
                      Sent from my LM-V405 using Tapatalk
                      • anothertech
                        • 1771
                        That's what i saw in the online update training. I have not seen one of the Pro C5300's yet, but that will be a welcome change.
                        • copier tech
                          • 8192
                          I look after 3 of the Pro 5110s & have yet to do a fuser they all are over 600k so its in the post!
                          • farhad
                            • Apr 2020
                            • 40
                            you can use the 7622 sp mode and reset the lubricant
                              THE op IS A NON-TECH.. HE DOESN'T HAVE THE SKILLS NEEDED.
                              he has to replace the lube bar before resetting the count.
                              you have commented on nearly ALL ricoh threads and you comments have been: late/wrong.
