c3002 "add toner" new developerbox
    • 37052
    #16
    Re: c3002 "add toner" new developerbox
    Originally posted by Mark Bbb
    C.T.: you mean swap the pipes?
    Won't there be contamination of cyan toner in magenta (or v.v.)?
    Other than the angle of one of the connecting "pipes" all 4 pumps are identical. As for cross color contamination, there is very little toner actually remaining in a pump. Definitely not enough to make a visible change of the print color.
    • Mark Bbb
      • Jun 2012
      • 1662
      #17
      Slim, ok if you say so...
      Everyday is just another day to learn new stuff, isn't it...
      • mikadonovan
        • May 2008
        • 2931
        #18
        Done this a hundred times. Just slide the metal plate back on the pump and vacuum it out, it takes 10 seconds. Now you have a pump ready to go. Be sure and vacuum/replace the supply hose.
        NEVER ASSUME ANYTHING
        • fshead
          • 2356
          #19
          the mpc3002 pumps is the same as mpc2800/mpc3300/mpc3501 pumps and yes they all go bad.......
          WHEN I GET THIS it is 90% always a bad pump.
          I go into service mode and ck VT reading if it around 3.5 to 5.0 it is undertoned.
          I will try a forced toner feed and see if reading changes if not swap out new or used pump..
          If it is K i will use a color one but 1st run forced toner on that color twice and then vacunm it out n swap........
          I only will swap from a machine in the field if i dont have a spare on hand...
          It is funny you wont see a add toner call for a while and then get 3 or 4 in the same month
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            #20
            Dear mga.
            With all due respect sir, but i can't make head nor tail of what you are writing.
            Greetings,
            Mark
            Sorry bad wording I know what I ment by it. I noticed you started life at Xerox me two those was the days take care
            Regards Mark
            • techsass
              • Dec 2010
              • 248
              #21
              Hopefully you've already got this working, but one other thought. Didn't the Cxx02 series have an RM version that used a different toner? I know the c5502 did.
              I remember techs having this issue because they would do the firmware update while on the call. The RM version had it's own ENGINE firmware that was different from the standard c5502. My memory isn't quite what it used to be & it might not have been the ENGINE firmware, but there was a bulletin regarding the firmware needed to correct the ADD TONER issue.
              • fshead
                • 2356
                #22
                Dear mga.
                Greetings,
                Mark
                i think he is saying if it cycles and runs "adding toner" but does not clear it is a pump.
                If the machine does not see a cartridge installed it is a toner chip or rfid board..
                basically one is mechanical and the other electrical..
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  #23
                  "Add toner, black" problem went away (for about 100 printouts from test chart Ricoh) after replacing (and initializing) the black development unit.
                  But now it's back.
                  I have cleaned (again) the ID sensors, swapped ITB unit and PCU. No good.
                  Yes, it is a original Ricoh toner bottle, more than half filled.
                  Printout quality was perfect (really black) before it went into "add toner" message.
                  There was no "nearly end" message (i guess).
                  It is the first time we have this problem on this type, and i guess it is the toner end sensor.
                  • copier tech
                    • 8121
                    #24
                    But now it's back.
                    Did you swap or replace the pump like we advised?
                    All you did initialising the dev unit was set the toner level in the unit temporarily not actually resolve the real issue.
                    A copier will call for toner BEFORE the the print quality Is affected.
                    • techsass
                      • Dec 2010
                      • 248
                      #25
                      If you haven't replaced the toner pump yet, then that is the 1st thing I would do. It is a very common failure point on that entire series going back to the c4500.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        #26
                        OK, gentlemen, i will do this wright now.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          #27
                          I noticed that the rubber pipe was not fully fit over the pipe(?) of the toner supply pump.
                          Some toner dropped in the machine, some in the pump...
                          Thank you al for you helping me out here!
                          Makes life easier.
                            • 37052
                            #28
                            But now it's back.
                            100 printouts could be the number of printouts from when the machine detects it needs to add toner and starts cycling the toner pump, toner pre-end, to displaying toner out. For some models it is 50, for others it is 100. At toner pre-end it should have displayed toner low but if no one is at the machine to see the display.
                            • mikadonovan
                              • May 2008
                              • 2931
                              #29
                              Makes life easier.
                              So the machine is now fixed? And the problem was the toner supply tube not secured to the pump? And it took 3 pages of advice and 2 weeks to figure that one out? Attention to detail, Dude.
                              • tsbservice
                                Field tech
                                • 7940
                                #30
                                Lol mika as perplexed you are imagine how he was
                                But agree it's good to listen carefully to the majority especially when this comes from experinced techs.
