MPC 3003 scanner section bend
  • kanagavel
    Service Engineer
    • Feb 2020
    • 78
    [Misc] MPC 3003 scanner section bend
    Hi friends, the problem is MPC 3003 scanner section bend because of some heavy thing fall down on top of the machine when ADF is not there so the home position sensor side the glass broken and the side slightly bend .so when i try to make copie or scan the top side totaly blured. so anyone can help me to solve this...
    Thank You.
  • copier tech
    • 8131
    Re: MPC 3003 scanner section bend
    Thank You.
    The mirrors are factory set the position is absolutely critical.
    I don't think you'll ever resolve this issue scrap the machine is my advice.
    • davel
      • Oct 2011
      • 1097
      Customer needs to buy new machine since they broke it.
      • GIUBOSS
        • 1398
        Thank You.
        not an impossible task but certainly not an easy one. Send us some photos of the damaged part, which, in my opinion, should be dismantled and restored to its original form. I believe only you can fix it by trying to straighten the folded parts.
        • kanagavel
          Service Engineer
          • Feb 2020
          • 78
          Thank you for the reply sir
          • kanagavel
            Service Engineer
            • Feb 2020
            • 78
            Hi sir, thank you for the reply. I will send you the photos soon. I tried already but still i can't get 100% let see...
            • thurmmy
              • Aug 2016
              • 102
              I've encountered this more than a few times. You just got to dismantle, locating bent/broken parts along the way, replacing repairing. Make sure everything is square and lined up when reassembling. Sometimes it is time consuming and frustrating but 99% of time it can be done. Good luck with it. You can do it!
                • 37406
                Obviously you have never had to replace scanner wires. All you need is a set of scanner positioning pins.
                The only thing that is factory set and cannot be adjusted in the field is the lens block assembly. You have to replace as a unit.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  Thank You.
                  I find if scanner frame is bent or twisted best to forget about it and charge customer
                  Regards Mark
                  • tsbservice
                    Field tech
                    • 7988
                    Good decision. It's fidle job and the mister customer should pay for this.
                    • Gift
                      • Mar 2011
                      • 2459
                      Most of this occasions I was able to re-bend the frame back to normal but sometimes the uniformity of the scan sharpness/geometry remains slightly uneven and due to all the bending the structural stability remains compromised.
                      In case there's no finisher installed I'd add that transport secury plastic thingy to the scanner as additional support.
                      Shurely not covered by any usual maintanance contract and I'd only go for that if the machine is owned by the customer.
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        You can use the scanner fixation tool (it is in the front cover or on the paper exit plate), which fixate the scanner unit during transport (and removed once at customer site)
                        That might help you to re-adjust the scanner.
                        But, if there are optical (carrying) things broken, perhaps it is difficult to re-adjust.
                        It depends which parts are broken...
