Format Hard Disk
  • bullet102
    • Jun 2020
    • 10
    [Misc] Format Hard Disk
    Is it possible to format a hard disk on a Ricoh MP C5503 via the Web Imagine Monitor or via accessing the device remotely?
    If not, how can I wipe the disk when next onsite?
  • copier tech
    • 8144
    Re: Format Hard Disk
    No you can't format the HDD remotely on the C5503 but the later models you can.
    To format the HDD log into service mode & run SP-5832-001
    • TonerMunkeh
      Professional Moron
      • 3865
      You'd be best off removing the HDD and formatting it with a caddy.
      Hit it.
        • 37489
        • bullet102
          • Jun 2020
          • 10
          Can I on the C5504? Got them to do too.
          Can you explain how I "log into service mode & run SP-5832-001"?
          • bullet102
            • Jun 2020
            • 10
            How? Where is the HDD located and how do I remove?
            • anothertech
              • 1769
              The answer is, no you can not get into service mode.
              This is for trained techs only, you need to call a tech to come perform this service for you.
              • bullet102
                • Jun 2020
                • 10
                • copier tech
                  • 8144
                  Yes, use the remote support app with this you can access service mode remotely.
                  • bullet102
                    • Jun 2020
                    • 10
                    Remote support app? Sounds exactly what I'm looking for. What do I need to do?
                    • copier tech
                      • 8144
                      If all he needs to do is wipe the HDD to delete the addressbook etc then this HDD format is ideal.
                      Remember a copier is not like a Windows PC not really any sensitive data stored on a copier hdd.
                      • copier tech
                        • 8144
                        RICOH RemoteConnect Support | Global | Ricoh
                        Drop us an email if you need it.
                        Firmware Update - Printer & Copier Firmware
                        • bullet102
                          • Jun 2020
                          • 10
                          Thanks, but I'm not sure what I'm looking at here? Am I looking for an app that I can use to remote wipe the hdd on my devices?
                          Sorry, bit confused as to what you are suggesting.
                          Think all I really need is to know what buttons to press on the device to wipe the disk. (How to get into the correct menu, where to look, what to press, etc)
                          • copier tech
                            • 8144
                              • 37489
                              That depends on what has been printed to it. If Disk Overwrite Security has not been activated the image data of recent jobs will still be on the HDD and can be accessed by someone who knows how.
