Ricoh Pro C5100s cyan issue.
  • tsbservice
    Field tech
    • 7949
    #16
    Re: Ricoh Pro C5100s cyan issue.
    This pattern definitely looks like depleted developer. You should find why following other Ricoh techs advices.
    • Draken
      • Jun 2020
      • 7
      #17
      SC320-02 is a Development Power Pack Output Error (C). And the CQ issue is with the Cyan. It is an output short, most likely in the development unit but could wiring from the power pack to the development unit. Replace the Cyan development unit.
      I have tried that already. I had an old cyan development unit that worked fine, Besides a banding problem. The current problem is the same with both units.
      • Draken
        • Jun 2020
        • 7
        #18
        Is it posable for it to be depleted after only 12500 copy's since I replaced it last?
        • copier tech
          • 8123
          #19
          Take the cyan dev unit out & visually inspect it see if it has depleted developer.
            • 37124
            #20
            Replace means with a new unit.
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              #21
              If you take a used development assembly from a other machine it would of be set up the machine it came from thats its now u/s when you install NEW developer with or without the assembly you need to run a set up for TD level etc
              Regards Mark
