I came across a customer last week, that for some unknown reason, has their Konica Minolta copier out of the internet, with a publicly routable IP address assigned to it. They were complaining of constant problems with their NEW copier. At one point, they complained that "someone" enable authentication on the copier, leaving them completely locked out of it. After troubleshooting their problems and removing the authentication requirement, it was discovered that for some reason they had programmed in a public facing IP address. Their copier was sitting out on the public internet, ripe for the picking.
This peaked my interest a bit, and I decided to do some searching and poking around at a very useful search site called Shodan. This isn't your typical search engine. It does not scan the internet to catalog websites; this search engine catalogs DEVICES. Devices that are connected to the internet, ripe for the picking. It allows one to search for key terms used in the software of the devices. It gives you a couple pages of results for each search, and a limited number of searches per day, for free. To get an extensive list requires a subscription, so if you happen to try it out, don't be fooled by the limited number of results you are able to view.
A few searches I tried for different brands of copier equipment produced some alarming results. So many devices with direct access from anywhere in the world, not only to their web interfaces, but the mail ports, FTP, etc..
Konica Minolta
Canon
Kyocera
Ricoh
Savin
Sharp
Xerox
These results are not encouraging to say the least. Encourage your customers to keep their equipment safe and off the public internet. I can't see any reason at all that a device needs a public IP.
Konica Minolta
Canon
Kyocera
Ricoh
Savin
Sharp
Xerox
