Ricoh MP2501 Trasfer roller
  • Zesti
    • Jun 2009
    • 308
    [Electrical] Ricoh MP2501 Trasfer roller
    Hi,
    Basically we're KonicaMinoltra techs. Happens to have work on couple of Ricoh MP2501s. There were some copy quality issues, checked the transfer roller biasing through springs and black roller holder at back end of machine. The holder seems to provide bias to roller but while checking it's showing either no or very high resistance that also varies with pressure on roller between biasing plate and roller shaft. Wonder if that's normal or should there be no resistance between roller shaft and biasing plate. The machine has total counter around 67k. Toner is original.
  • copier tech
    • 8100
    Re: Ricoh MP2501 Trasfer roller
    Originally posted by Zesti
    Hi,
    The drum life on the 2501 is only around 60k & when they reach life you start getting background on the prints.
    If the solids are grey (do a counter print & look at the sold triangle) I replace the developer at the same time.
    • Zesti
      • Jun 2009
      • 308
      Thanks Copier tech. The machine has copy quality issue of filling solid black, jitters in triangle of counters. That's why I checked the transfer roller. Any clue about what I'm trying know about biasing of transfer roller?
      • copier tech
        • 8100
        If you can post a sample of the quality issue it would help to diagnose the quality issue.
        Scan the counter page in for example.
        • TonerMunkeh
          Professional Moron
          • 3865
          At 64k if the PCU hasn't been rebuilt already, that's the first thing to try.
          Part numbers:
          B0399510 - Drum
          AD027018 - Charge roller
          AD042083 - Drum blade
          AD042058 - Charge cleaning roller
          D1589640 - Dev
          D1583820 - PTR
          The PTR isn't at fault, it's the worn PCU parts.
          Hit it.
            • 36745
            Early symptoms of a worn drum. In another 3K to 8K you will start getting drum spots. PM time!!
            After market drum, developer and toner will also cause loss of fill. Use only Genuine Ricoh. The same goes for your KM machines, use only Genuine KM.
            • Polo-022
              • Sep 2007
              • 481
              Transfer roller current amount, depends on paper type, paper tray and paper width and it varies during printing.
              Low (positive)at the leading edge, high during image transfer and low again between pages.
              Negative current is applied to clean transfer roller from any toner particles.
              • Zesti
                • Jun 2009
                • 308
                Thanks Polo,Valuable information. I've already gone through other threads about replacement of OEM parts only. But in this case I'm trying to understand the technique, how Ricoh is delivering/providing the Bias voltage to PTR. Out of curiosity I shorted (Somehow) the the PTR biasing plate to PTR shaft and the result is attached. Above one is problematic image and below one is after my experiment.
                Any expert advise...
                • Polo-022
                  • Sep 2007
                  • 481
                  The expert advices have been given above : replace all PM parts.
                  • mga
                    Copier Technician
                    • Dec 2010
                    • 1393
                    If that was a photocopier copy of the counter sheet it's the optics
                    If it a counter report it will be the pcu pm parts you can use a type 1027 pcu complete unit if you not sure on replacement of parts
                    Good luck
                    Regards Mark
                    • Zesti
                      • Jun 2009
                      • 308
                      Both the prints were counter printouts.
                      The problem was solved but I couldn't get exact answer to my question. I'll check on another working machine.
                      Thanks anyways all and I really find some valuable info.
                      • GIUBOSS
                        • 1382
                        Hi,
                        have you tried looking in the service manual or point to point electrical section?
                        • Zesti
                          • Jun 2009
                          • 308
                          Nothinf specific in PP manual, regarding my inquiry...
