IMC3000 NVRAM zero counter
  • GeorgeBest
    • Jul 2009
    • 505
    HI,
    Does anyone know if the procedure of the zero counter/NVRAM is the same as in the MPC3003/Metis machines ?
    Thanks in advance . .
  • tsbservice
    Field tech
    • 7635
    Re: IMC3000 NVRAM zero counter
    Why do you need that? It's illegal in most parts of the world.
    • GeorgeBest
      • Jul 2009
      • 505
      Just asking . . . .
      • DRichard
        • May 2008
        • 482
        Originally posted by GeorgeBest
        Just asking . . . .
        Well then, if you're just asking...Sure, why not.
        "Enjoy every sandwich."
        -- Warren Zevon
        • anothertech
          • 1714
          HI,
          Yes, there are people that know the procedure. The real question is, are they going to tell you the procedure?
          I think no.
          • GeorgeBest
            • Jul 2009
            • 505
            Wel I know the procedure, had to do it on an MPC3003 because there was an error with the NVRAM causing strange behavior of the machine.
            The quistion therfore is because of simular problems on an IMC3000
            I think no.
            • GeorgeBest
              • Jul 2009
              • 505
              Thnx . . .
              • GIUBOSS
                • 1329
                Writing the procedure here would be irresponsible as well as illegal. The problems are not always solved by resetting the nvram indeed it could be worse. It is more appropriate to buy the new one.
                  • 35061
                  How about a description of the problem. One of us might be able to help you repair it properly.
                  • GeorgeBest
                    • Jul 2009
                    • 505
                    Well as I said before I don't need to know how the procedure is, I know it and of course it should not be written here.
                    Read my question, I just asked if it is the same on the IMC's
                    • GeorgeBest
                      • Jul 2009
                      • 505
                      It didn't start up or was very slow . . . the new NVRAM was the solution, on advice from Ricoh itself !
                      • GIUBOSS
                        • 1329
                        Ok, but I also suggested that you take the new nvram.
                        • copier tech
                          • 7931
                          Exactly! I can't think of any issue with a copier that you would need to reset the main counter to resolve a fault.
                          • GIUBOSS
                            • 1329
                            It can happen when you load a damaged firmware, or some technical magician changes all the standard passwords.
                            • Oze
                              Ricoh Fanboy
                              • Jul 2008
                              • 1663
                              It can also happen when Ricoh send instructions directly to the customers on how to encrypt their machine and they bugger it up
