Firmware language display RICOH MP C4503/C5503
    replied
    Re: Firmware language display RICOH MP C4503/C5503
    Originally posted by tecnomarco
    hello to all I bought used copiers Ricoh mp c4503 / c5503 I need to change the language on the display (Italian language is required) can someone help me? thank you
    We can supply you with the Italian language should you require it.
    Firmware Update - Printer & Copier Firmware
  • tecnomarco
    replied
    Operativo panel, language 0 and language 1 ..D1491490Q same two copier c4503 and C5503
  • GIUBOSS
    replied
    I have two copiers c5503 and c4503 looking at the firmware installed in the administrator section they have the same ... D1491490Q but the c5503 has 5 languages ​​loaded including the Italian one, in the administrator section the C4503 has only two languages ​​preloaded .... English and French what can I do to add the Italian language? thank you
    also have the same firmware Operation panel D1471490G or updated both ??
  • tecnomarco
    replied
  • tecnomarco
    replied
    GIUBOSS ho due fotocopiatrici c5503 e c4503 guardando i firmware installati nella sezione amministratore hanno lo stesso ...D1491490Q ma la c5503 ha 5 lingue caricate tra cui quella italiana ,nella sezione amministratore la C4503 ha solo due lingue precaricate....inglese e francese cosa posso fare per aggiungere la lingua italiana? grazie
  • tecnomarco
    replied
    Originally posted by GIUBOSS
    Then update the operator panel, I haven't found the language firmware.
    can you explain what I can do I tried the 5-009 as you suggested but the languages ​​available are always those two....ma sei italiano se si parliamo italiano
  • GIUBOSS
    replied
    Thank's GIUBOSS my problem is the language is not preloaded....I would need a firmware D1491490Q which contains the Italian language
  • tecnomarco
    replied
    I didn't know about that SP setting. He might want to compare setting between the 2 machines and change the one that has 2 languages to match the one that has 5.
    replied
    try to change the switches in setting sp 5-009 to display the desired language (if preloaded in the machine)
  • GIUBOSS
    replied
    this is the firmware language "0" and "1" D1491490Q, for both copiers the same firmware but while one has 5 languages ​​preloaded (including Italian) the second only 2 (English and French)
    replied
    The only thing that I can think of is that one of them is from the first production run, before they started loading all 5 languages. Reflashing both language firmware entries might correct it. If not it will allow you to select the 2 languages you wish to have available to the user. One thing you might check is if the part number on both BICU boards are the same. The number stamped on the board that has the production letter not the one for the bare board.
  • tecnomarco
    replied
  • tecnomarco
    replied
    thanks slimslob I wanted to tell you that I have two of these photocopiers on the other the Italian language is there and I solved it immediately ... is it possible somehow to use the firmware of this second photocopier and install it on the one that does not have the Italian language?
    replied
    If you scrolled through all the languages then as far as I know if a language is not preloaded at the factory on those models, the only solution is to contact Ricoh-EU. You may even have to pay to have a custom language firmware created.
  • tecnomarco
    replied
    have check the language but italian language is not loaded if the language is not loaded what should I do to have the Italian language? i must load the new firmware? thanks
