MPC3503 won't print out faxes
    • 37495
    #16
    Re: MPC3503 won't print out faxes
    User Switch
    SW11 Auto reduce should be ON it's set to off
    I'm sorry but Auto Reduction is not SW11. It is SW10 bit 3. Having it off is Default. All that it will cause is that an alarm will sound and user will be prompted to load the required paper size. Many people do not want the image reduced.
      • 37495
      #17
      Originally posted by withnail
      As requested here are System Parameter, User Parameter and Non Defaults lists
      I am seeing two potential settings that could be your problem.
      1. User Switch SW14 bit 0, Night printing mode is ON. Faxes will only be printed when machine goes into night mode. If night mode is not set up on the machine, it will never go into night mode.
      2. User Switch SW32 bit 0, Select destination type priority is set for Electronic Output. Should be set to Papwer Output unless some type of fax forwarding is being used.
        • 30222
        #18
        Auto Reduction is WHAT is will reduce oversize to fit on paper
        Auto Reduction
        Sets the machine to reduce the size of a received fax if it is too large to print on a single sheet of paper.
        Note that the machine only reduces the size down to 74%. If further reduction is required to fit the fax on a single sheet, it will be printed on separate sheets without being reduced.
        Default: [On]
          • 37495
          #19
          Auto Reduction
          Default: [On]
          Not advisable with most industries where they want legal sized faxes printed on legal paper. That includes medical, legal, oil field construction, education and government. But that is beside the point. Your answer has nothing to do with faxes not being printed.
          Oh by the way, I have been working on fax since Group 1 was the standard. That was 6 minutes a page or 4 minutes compressed. Not all makes and models supported compression.
            • 30222
            #20
            Hilarious Oh by the way as most companies don't even use legal size paper any more
            Bravo AH Since I've worked for two of the largest Copy company's in the World we ALWAYS set Faxes to Auto Reduce ON SETUP
            Print Received File
            Sets the machine to automatically print the faxes received into memory or store them for later manual printing.
            This setting appears only for the Type 2 model.
            Default: [On]
            On
            Automatically print out the received faxes and delete from memory.
            Off
            Store the received faxes in memory for manual printing.
            • withnail
              • 59
              #21
              User Switch
              I changed Auto reduce to off when I returned for the reports to see if it changed anything which it didn't.
                • 30222
                #22
                Did you check this setting
                Print Received File
                Default: [On]
                On
                Off
                • withnail
                  • 59
                  #23
                  Print Received File
                  Default: [On]
                  On
                  Off
                  I take it you mean Reception File Settings/Print turned on? Yes this is set to on with forwarding and store set to off. Locked Reception file is also turned off on the same page
                    • 30222
                    #24
                    What happens it you turn fax forward on does it send the file?
