Mpc 2003 not able to load web browser
  • Stephendupey
    • Oct 2020
    • 10
    I have a client who has a mpc 2003 with a static IP, and when I try log into the web browser it gives 404 not found. Is there anything specific that could be causing that?
    This client also has a Mac laptop that he prints from, is there any way for them to be able to print in colour from the laptop without postscript?
    • 37513
    Re: Mpc 2003 not able to load web browser
    Newer model Mac with latest OS X have been able to print in color for about 4 years. Just no way to tell it not to do so. If the document has color it will print. Also no way to enter User Code.
    • sandmanmac
      • 3981
      This sounds like a new setup to me.
      Can you confirm if the WIM was working for the client, and then just suddenly stopped, or you have no idea if it was working prior to your installation?
        can you post the network config page from SMC report.. sounds like setup was not done correctly to me.
        what print driver are they using?
        is it configed to B&W only?
          • 37513
          Did someone try to setup a self signed Device Certificate. If so WIM will require that you access it as https and will give a 404 not found if you try to access as http device.
            • 30255
            Check the security settings
            • Stephendupey
              • Oct 2020
              • 10
              I'm not sure if it was working before, the machine had been on site for a while, I was at the client for quality issues, but I wanted to set up @remote at the same time, which is when I discovered that I couldn't get on the web browser
              • Stephendupey
                • Oct 2020
                • 10
                Originally posted by terramobil
                Is HTTP diabled? If so, you can switch it on using telnet.
                How do you do that?
                  • 37513
                  First check SP 5895-001. It should be set to 1. If set to 2 WIM could be disabled.
                  • Stephendupey
                    • Oct 2020
                    • 10
                    OK, I'll do that
                    • copier tech
                      • 8164
                      Try another browser, chrome for example.
                      Also connect your laptop if you have Windows.
                      Updating the firmware can also resolve this issue.
                      • Stephendupey
                        • Oct 2020
                        • 10
                        I tried. Chrome, internet explorer and Firefox, I also did the web interface firmware
                        • FrohnB
                          • Jul 2017
                          • 1919
                          As others have said....
                          • I would start with updating ALL firmwares.
                          • Try switching the machine to DHCP to Auto obtain an address, and then see if you can access WIM with that IP. Then you can switch it back to Static.
                          • Check security settings (User tools --> System settings --> Admin. tools --> "Network Security Level" {usually set to "Custom"}).
                          • I think there is an SP that can be toggled to disable WIM.....SP 5-885-205 should be set to "0".
                          • Are there any Admin. Authentication settings set?
                          • You said you were going to set up @remote, but couldn't access WIM to do that. Did you try to do it from the machine's panel after that? Was it successful? If not, you can execute SP 5-870-003, and then 5-870-001, if those fail to execute then you may have a device certificate issue.
                          Omertà
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Reset 58xx 4x# in factory mode & make sure firmware is upto date you can only print via airprint on mac without ps3
                            Regards Mark
                              • 37513
                              Not true. Apple has included generic PCL support for years.
                              Add printer -> IP and chose: LPD on protocol, set the ip address, in the queue field you can write anything. In the print using field chose Generic PCL Driver. and it is done.
                              Depending on the age of your Mac you might be only able to print B/W.
