Mpc 2003 not able to load web browser
  • copier tech
    • 8142
    #16
    Re: Mpc 2003 not able to load web browser
    Originally posted by Stephendupey
    I tried. Chrome, internet explorer and Firefox, I also did the web interface firmware
    This is your issue you skipped all the other firmware.
    • heeks
      • Jun 2012
      • 19
      #17
      Did you try to delete and re-create an https certificate ?I had this behaviour once and it worked fine after this trick.
      • mga
        Copier Technician
        • Dec 2010
        • 1393
        #18
        Not true. Apple has included generic PCL support for years.
        Add printer -> IP and chose: LPD on protocol, set the ip address, in the queue field you can write anything. In the print using field chose Generic PCL Driver. and it is done.
        Depending on the age of your Mac you might be only able to print B/W.
        News to me printing from mac to mpc2003 without ps3 are you sure I will investigate
        Regards Mark
          • 37480
          #19
          I believe that the color 03s is where Ricoh introduced their own PostScript emulation. It is part of PDF Direct. Just like the emulation that HP uses it does allow printing from Mac but not all PS3 features are available.
          • copier tech
            • 8142
            #20
            No, the PS emulation was on the xx04 & later models.
            • Gary k
              • Jan 2020
              • 10
              #21
              Have you tried from your laptop or another computer? might be worth a try.
              • StephenB
                • Aug 2015
                • 243
                #22
                I'm just sharing where I had a C3503 do the same thing, WIM blocked and would NOT connect.
                I executed SP 5801-10, 20, 25 This has worked twice for me.
                Also try...
                Check SP 5828-091 =1
                Also, In user tools System / Interface settings / Permit SSL/TLS communication is set to cypher text /Clear Text.... Then reboot
                Good luck
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  #23
                  Yes can only print via airprint missing loads of fonts missing not much use when using mac it's OK for a iPhone or ipad.
                  Regards Mark
                  • DRichard
                    • May 2008
                    • 482
                    #24
                    +1 on this. Whenever we know the customer is going to be using Macs, we ALWAYS recommend they purchase the optional PostScript and not rely on the emulation version. We occasionally have to follow up with them afterwards if they wouldn't go with it at the outset and found the emulation to be too little or if they later added Mac users to their staff.
                    "Enjoy every sandwich."
                    -- Warren Zevon
                    • DH1980
                      • Mar 2009
                      • 52
                      #25
                      I had a machine that would not load WIM and it was the antivirus software. Turned it off and it worked fine.
