MPC4503 Print out dirty dot dot at center
  • chin1202
    • 12
    [Misc] MPC4503 Print out dirty dot dot at center
    Hi MPC 4503 Print out have dirty dot dot at center, Pls Help
    *already change c m y k drum and heater unit
  • 8T2
    • Aug 2015
    • 257
    Re: MPC4503 Print out dirty dot dot at center
    What are the print and PM counts? If you already replaced the drum I'm leaning towards the Fuser sleeve or possibly ITB
    Sent from my WAS-LX1 using Tapatalk
    • chin1202
      • 12
      already try change heater unit
        • 8164
        You replaced all PCU were they genuine Ricoh? if not did you replace the charge rollers?
        • mga
          Copier Technician
          • Dec 2010
          • 1393
          That is a cheap black drum {compatible} seen a lot
          Regards Mark
            • 37511
            Could also be the ITB cleaning unit past PM count.
            If paper is Short Edge Feed it could be a dirty transport roller.
            • 8T2
              • Aug 2015
              • 257
              In that case I think it's the PCU or possibly ITB. Have you tried switching 2 of the PCU's to see if the marks change colour?
              • mga
                Copier Technician
                • Dec 2010
                • 1393
                Hi 8t2
                If they black spots you can't swap with colour pcu
                Regards Mark
                • 8T2
                  • Aug 2015
                  • 257
                  Originally posted by mga
                  Hi 8t2
                  Dammit you're right, forgot the Bk is different on these
                  • skinnyb
                    • 291
                    I interchange them all the time. P/N is different but they fit and work fine. I use the 04 series drum in the 03 too. They are cheaper. Dev units are unique though.
                    Sent from my LM-V405 using Tapatalk
                    • Pixtech Frameworks
                      • May 2020
                      • 238
                      It can be caused by the following:
                      1. Dirty transport roller
                      2. Paper exit roller
                      3. Cleaning blade (black developer unit).
                      Cleaning 1&2 with wet cloth (water)
                      4. Bad opc drum
                      • Mark Bbb
                        • Jun 2012
                        • 1662
                        Please,
                        mention counters of
                        pcu (unit or parts?), developer(box), F.U., paper transfer, ITB (cleaner).
                        Do you use original Ricoh parts?
                        Do you rebuild the pcu yourself?
                        So many questions, so little info !!!
                        • Gab
                          • Aug 2015
                          • 671
                          Are =these dots when copying?
                          Do some repeated A3 copies . Are those dots repeated at regular spaces (as it looks like ) ? If yes the problem is at drum or developer roller or charge or upper fuser. To find which item you mesure the distance of the dots and compare this with the around of the cylider (drum or charge or.....)
                          • luca72
                            • Oct 2017
                            • 1781
                            unfortunately despite having enlarged the photos, it is not seen very well, it does not look like the development groups (spots too large), to me it looks like the sleeve film cremated, in fact if you look at the black pattern the dots are almost white, as if the toner peeled off the sheet to stick to the film, you do some "output check" of the fuser without opening the toner bottle door?
                            "I'll be back"
                            • fshead
                              • 2376
                              stop the printout b4 it goes thru fuser and inspect......
