MP 301SPF Toner Density/High Background
    • 37491
    #16
    Re: MP 301SPF Toner Density/High Background
    Originally posted by FrohnB
    They only last 10k because they are junk!
    When we first started selling this series, it only took about a month before we had a rash of failures at about 10 - 15k with the PCDU's. No matter what you do, you can't "bring it back" to normal, except for replacing the unit. Replacing just the developer might work for a short while, but not a sure-fire solution. Shortly after realizing the units suck, we found out that you can put the 411844 (Type 1515) PCU's in the MP 301 machines (break off a pin on the frame of the machine that meshes with the face-plate of the PCDU). Ever since then, we've had them go to the actual 45k yield they are rated for. Not sure what they did to the D127xxxx units, but as I said, they are JUNK, and we refuse to use them!! Have lodged MANY complaints with RICOH about them, but nothing has ever been done.
    Sounds to me like t might be similar to the development roller filming issue Ricoh had with the 35/45 and 40/50 ppm models.
    • MIKON
      • Jul 2015
      • 187
      #17
      Are you running sp2801 after pcu replacement?
      • Keegan Chetty
        • May 2015
        • 113
        #18
        We've had every unit (atleast 100) fail within 15k copies, started using rebuild kits which are way cheaper and comes with gears and so far it has been working *fingers crossed*
        • Polo-022
          • Sep 2007
          • 486
          #19
          Yes i do.
          • Polo-022
            • Sep 2007
            • 486
            #20
            Could it be the TD sensor, calibrated to a "higher density" level related to the MP201sp TD sensor??
            • JaysOnTheEDGE
              • 61
              #21
              The toner formulation is different between the 2 series so its a possibility, I do not miss working on these though I went through so many PCDU units such a environmental waste.
              • Brianneoe
                • May 2015
                • 318
                #22
                The toner hopper is a major point of failure with these machines. If the toner hopper is defective you will see toner all the way down the bottle when you remove the bottle and the discharge lamps above the PCU will be coated with toner. When the hoppers are working as they should the machine will run clean and you will get a better yield from the PCU.
                • mga
                  Copier Technician
                  • Dec 2010
                  • 1393
                  #23
                  This machine don't have discharge lamps
                  Regards Mark
                  • anothertech
                    • 1769
                    #24
                    Looks like he's refering to the quenching lamps. They do get covered with toner. I never thought of replacing the hopper to help with this problem, sounds like a good tip.
                    • Gab
                      • Aug 2015
                      • 671
                      #25
                      usually this probles is coused when developer is fatigued
                      • JonManchester
                        Technician / Shop Manager
                        • Aug 2013
                        • 103
                        #26
                        The problem with these PCDU's are due to the fact they are meant to run at 16 pages per minute not 31 pages per minute. That being said we have customers that run low volume and have little issues with these 301 machines. We have customers that run average to high monthly volumes and the PCDU's just cant handle the speed,, Hence forth the reason the mp305 got a completely redesigned PCDU for the speed. This MP301 series has been a joke, that was improperly engineered. We never had these issues on MP161's and they are the same PCDU's structure minus the different mix for the toner and dv. I cant wait till we have no more in the field, due to the amounts of PCDU's we go through.
                        Live for something or die for nothing.
                          worn out developer would leave WASHED out prints.
                          • Polo-022
                            • Sep 2007
                            • 486
                            #28
                            I agree with you Jon, with customers running high monthly volume, PCDU's (D127-XXXX or 411844 ) cannot run to life. Gears get stripped too early. It doesn't happens to the predecessors.
                            This question has been answered.
                            I would like to have a good print quality for 30K. prints at least, with one PCDU type or another and i know that 411844 Type
                            runs very good.
                            So, is it the D127-XXXX itself the early failure with toner density/heavy backgroung, or the toner Type 301, maybe the SP adjustments?
                            What if i use toner type 201 on MP 301???
                            Many thanks to all colleagues for your posts...
                            • copier tech
                              • 8144
                              #29
                              I have about 50 of these in a school all low use & I never have any major issues with them, or the PCDU failing too early however they rarely hit the PM life.
                              The first signs they need replacing is overtoning. I guess this model was built with budget in mind as this PCDU design has been around for nearly 20 years!
                              • Klydon
                                • Mar 2009
                                • 243
                                #30
                                Just to echo the experience of others here along with my own.
                                In most cases, it simply doesn't matter which PCU you use (411844 or D1272110). The performance of the machine revolves around what the volume is. IF the machine is run at low volume or even close to suggested volume, you hardly ever hear from them and they generally run fairly well. If it gets pushed hard on volume, the PCUs are junk and won't hold up. In addition, the hot roller won't go 90K either like it is supposed to. The running joke here is a 301 PM is a hot roller and PCU.
                                These machines are so bad, I generally take a PCU and hot roller in on every call on one unless I was just at it. Like many, I can't wait for these suckers to just go away.
