banding ricoh 5100
  • hernan
    • Nov 2020
    • 7
    banding ricoh 5100
    Hi everyone, I have a Ricoh pro c5110s, and this printing fails, can someone help me? I don't know what it can be, thank you very much.
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: banding ricoh 5100
    Hallo,
    Can you print off a PM counter list and upload it please?
    Hit it.
    • hernan
      • Nov 2020
      • 7
      Bands look the same in all 4 colors. Thank you for your supportive response. Attached as requested!!
      • TonerMunkeh
        Professional Moron
        • 3865
        Hello again,
        That's the commissioning status, not the PM counter. When you first go into SP modes, there's an option that says something like "PM Counter / Manual New Unit Set" on the same page as System SP, Printer SP etc. Go to "counterlist printout" in there and upload that one please.
        With the banding affecting all colours could be ITB, PTR or fuser, but we'll see when you upload that file.
        Hit it.
        • hernan
          • Nov 2020
          • 7
          sorry !! uploaded again.
            • 37508
            On the Commissioning report I am seeing a lot of 0 remaining item that are showing as having been replaced. To me that indicates a production machine that is being highly under used and doing a lot of very small jobs for a production machine. I have a feeling that your toner consumption is higher than what is specified in the Product Support Guide and you are using a lot of waste toner bottles.
            • hernan
              • Nov 2020
              • 7
              My client has a small printing company and does not make a large number of copies, he has a very good print quality in full lengths and photographs, but these marks come out in half tones, I don't know the causes.
                • 8164
                Have you tried running DEMS?
                Execute DEMS (SP3-040-001)
                When the gap between development
                roller and OPC drum changes, color
                inconsistency will occur due to changes
                in toner adhesion. CH-C1 Pro supports
                DEMS
                  • 8164
                  Your firmware is a little out of date, not that would really help your issue but might be worth a try loading the latest package.
                  • JaysOnTheEDGE
                    • 61
                    Are your test prints off the engine or the fiery? i ask because i had a similar banding issue with a customer running a gray background you could see a magenta band it it ended up being a setting in the fiery that was causing the issue.
                    Run the DEMS as mentioned before Check the ITB belt guide mylar, it gets toner build up.
                    Almost looks like your getting shock or jitter. lots can cause that especially in the fusing and transfer area. Especially if running a coated or thicker paper.
                    • anothertech
                      • 1771
                      Are those streaks running lead to trail?
                      • bat
                        • Sep 2008
                        • 140
                        This is a Shock jitter, difference in the rotation speed of the ITB motor and Registration motor. Read RTB No.: RD137039a.
                          • 37508
                          You can't attach that RTB? Either that or provide the corresponding TSB number used by Ricoh-USA?
                            • 8164
                            Search this document for RD137039a
                            https://mega.nz/file/BAdAzJgL#V6tmrz...CpeVmmmVy5xeek
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              Same same lines in all colours I would check ptr assy and wax bar in there
                              Regards Mark
