supply toner unit & toner bottle motor rotating during working but toner bottle only rotate while photocopy up to 200pieces , if keep on photocopy the reading of vsg getting high up to 0.9 could not maintain at 0.45
td sensor reading 01 and 02 is 4.5 voltage. normally every 100 copies toner bottle rotate and loading toner to supply unit ( am i right ). any suggestion
thanks
thanks
