Light Copy mp6500
  • hsh6049
    • Jul 2012
    • 64
    Light Copy mp6500
    supply toner unit & toner bottle motor rotating during working but toner bottle only rotate while photocopy up to 200pieces , if keep on photocopy the reading of vsg getting high up to 0.9 could not maintain at 0.45
    td sensor reading 01 and 02 is 4.5 voltage. normally every 100 copies toner bottle rotate and loading toner to supply unit ( am i right ). any suggestion
    thanks
  • Codex
    • May 2008
    • 704
    Re: Light Copy mp6500
    Hello
    It's normal that the bottle rotates in that way, because the toner falls in the toner hopper, and only from there in the development unit, this is caused by Td/Id sensor readings, the rotation of the bottle by the toner end sensor in the hopper unit.
    Light copies are a big problem in this machines, is the toner original? The developer new? Drum original? Also clean the exhaust filters and check the transfer unit, if the belt is dark brown change it, change or clean the bias roller. Check the RTB's for "Light copies", use the search function here, they was posted here time ago.
    Inviato dal mio SM-G935F utilizzando Tapatalk
    Memento Audere Semper
    • hsh6049
      • Jul 2012
      • 64
      thanks. a lot let me study the past record
        • 37488
        More often than not when any martini model when you start experiencing light copies the ID sensor for the PCU is dirty. It is located on the PCU frame directly below the drum cleaning station. If toner is leaking from the cleaning entrance seal, the ID sensor get coated with toner. This causes the image to look darker so ProCon thinks the machine is over toned. SP 3001-001 will be high possibly at or near 255.
        • mikadonovan
          • May 2008
          • 2931
          Make sure the filters are clean. Dirty filters cause a high temp situation in the cavity causing CQ issues and failure of the toner supply unit. I have seen toner cake in the hopper causing it to eventually lock up. Fresh developer would probably help, too.
          NEVER ASSUME ANYTHING
          • mga
            Copier Technician
            • Dec 2010
            • 1393
            thanks
            This series {martini} is the best machine ricoh has ever made.
            Being a older model you may need new Dev assy if you haven't give dev assy good clean including mag roller redev with oem dev and setup correctly as all user as said make sure all filters are clean and around dev and drum assy
            Regards Mark
            • hsh6049
              • Jul 2012
              • 64
              the reading for3001 01 56 .entrances seal is under good condition no leaking
              • anothertech
                • 1769
                It is debatable as to how good this series is. I don't think they are very good machines. Look at the MP6055, and the MP C6004, now those are good machines.
                  • 37488
                  Let's give them a few years. The basic mechanics of the martini series has been in use for over two decades.
                  • anothertech
                    • 1769
                    How about the MP 6054 and the MP C6003, basically the same machines and have been around for quite a while now. Ricoh has a lot of good machines, but I do not consider the MP 6500 one of them.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Come on no way there no way the new ricoh Mono series are as good as the martini as for the mpc6004 great machine but colour
                      The martini engine has been about for years and still going as a new machine
                      Regards Mark
