sp c250 wifi keep discoonecting
  • Marwanalhajbi
    • Jul 2018
    • 72
    hello all,
    i have a sp 250sf connected wifi however it keep disconnected on sleep mode sometimes after 2 or 3 hours or day or two ,
    any suggestion please?
    please note that the customer refuses to keep it aweak .
  • Polo-022
    • Sep 2007
    • 481
    Re: sp c250 wifi keep discoonecting
    Install MAIN-PDL Firmware, M20456655R. Released from 07/07/20.
    • Marwanalhajbi
      • Jul 2018
      • 72
      i did no result sir
      • Polo-022
        • Sep 2007
        • 481
        Static Ip?
        • Marwanalhajbi
          • Jul 2018
          • 72
          Static Ip?
          i tried both static and dhcp won't help
            • 36883
            Are you using Ricoh's internal WiFi option or an external WiFi extender/AP?
              What's the strength of the wireless signal?
                • 8105
                Originally posted by Marwanalhajbi
                hello all,
                This is a known issue, update the firmware.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3945
                  If the signal strength ever dips below 80%, the connection will likely drop.
                  Ricoh wireless SUCKS, as mentioned countess in countless threads on CTN.
                  • Marwanalhajbi
                    • Jul 2018
                    • 72
                    internal sir
                    • Marwanalhajbi
                      • Jul 2018
                      • 72
                      good to know,thank you i will pass this information,however ,do you thing if i put the wifi router close to the printer i would solve the issue?
                        Can you plug the copier into an ethernet jack and then you can use the wifi of the router to print?
                        PS - You may try downloading the Wifi Analyzer app on your phone and you can see the strength of the wifi in different locations throughout the building. See video:
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          you can also connect a repeater ...
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Yes this is the best thing to do
                            Regards Mark
                              • 36883
                              internal sir
                              That is your problem. There are many WiFi range extenders with ethernet jack available, some for under $50 such as the Netgear AC750.
