Ricoh mp7500 strange problem, broken polygon motor ever 100k copies
Re: Ricoh mp7500 strange problem, broken polygon motor ever 100k copies
I cant find that in service manual too, never mind problem is sloved. I write that the problem is solved, for someone if have same problem,easy to find solitionComment
Sent from my SM-G960U using TapatalkComment
Hi all
I have strange problem with my Ricoh MP 7500, poligon motor problems repeats every 100 000 copies. Change poligon motor working 100 000 copies with out problem after that problem with copy. No error code but blurry print an jaming. In the begining i cant figure out what is the problem becouse no sc code. One tehnician with lot of experiance told me to change poligon motor. After i change problem disapear, today after 2 months and 100k same problem. Put in 4th poligon motor in working ok. Already 3 motors in trashi must find what is causing polygon motor defects
i see this problem in last year and my problem in power supply
test and change your machines power supplyComment
