Ricoh mp7500 strange problem, broken polygon motor ever 100k copies
  • m_donakov
    • 213
    Hi all
    I have strange problem with my Ricoh MP 7500, poligon motor problems repeats every 100 000 copies. Change poligon motor working 100 000 copies with out problem after that problem with copy. No error code but blurry print an jaming. In the begining i cant figure out what is the problem becouse no sc code. One tehnician with lot of experiance told me to change poligon motor. After i change problem disapear, today after 2 months and 100k same problem. Put in 4th poligon motor in working ok. Already 3 motors in trash i must find what is causing polygon motor defects
    Re: Ricoh mp7500 strange problem, broken polygon motor ever 100k copies
    Originally posted by m_donakov
    Hi all
    I have strange problem with my Ricoh MP 7500, poligon motor problems repeats every 100 000 copies. Change poligon motor working 100 000 copies with out problem after that problem with copy. No error code but blurry print an jaming. In rhe begining i cant figure out what is the problem becouse no sc code. One tehnician with lot of experiance told me to change poligon motor. After i change problem disapear, today after 2 months and 100k same problem. Put in 3 th poligon motor working ok.
    are you initializing the polygon each time?
    • m_donakov
      • 213
      No i dont please tell me how to do it?
        RTFM
        • m_donakov
          • 213
          RTFM
          Please explain me i cant unterstand what us RTFM
            Read The Fucking Manual
              I don't mind lending advice... but I refuse to do your homework for you.
              you claim to be a tech... show ME you are .
              • m_donakov
                • 213
                Sorry but cant find it in SM. I only read it that Automatic Adjustment of drum should be made after replace LD unit. If you can explain me will be a lot of help for me if you cant that is. Thanks anyway
                • anothertech
                  • 1771
                  Phil I don't see anything in the manual about initializing the polygon, what page did you see that on?
                  • davel
                    • Oct 2011
                    • 1107
                    Never heard of initialisation for polygon motor, are you sure you are thinking of correct brand/model.
                    • copier tech
                      • 8172
                      Maybe Phil B should read the manual ..........
                      • m_donakov
                        • 213
                        Can anybody help with the problem?
                        • MIKON
                          • Jul 2015
                          • 188
                          Check the flange on the drum drive in the back to see if the screw fell out
                          • m_donakov
                            • 213
                            I check that when i first time got that priblem, everting is ok, Problem is fixed for 100k when i put another polygon motor, but i cant figure what is the problem. I cant change polygon motor every 100k
                              • 37532
                              Are you absolutely positive that there were no Service Codes. It could be a Level C Service Code. SCs that are not shown on the operation panel. They are internally logged. Check the SMC report. If the machine halts it could a code in the SC310~SC317. Many are sensor errors that could affect image quality.
