Lanier MPC3002 Magenta CQ the same after replacing drum unit
  • bolton454
    • Jun 2011
    • 7
    [CQ] Lanier MPC3002 Magenta CQ the same after replacing drum unit
    Hello community,
    I have Lanier MPC3002 with an issue with the magenta color. The marks are vertical and 32mm apart. I replaced the drum unit since the foam roller (10mm) damaged but the same issue occurred with a rebuilt drum unit.
    The CQ lines and voiding happen when I use the scanner or the printer. Not able to load images for some reason.
    Thanks for your help.
    Kenny (Bolton454)
    Re: Lanier MPC3002 Magenta CQ the same after replacing drum unit
    Originally posted by bolton454
    Hello community,
    Kenny (Bolton454)
    did you check the dev unit?
      • 16766
      Hello community,
      Thanks for your hel
      Kenny (Bolton454)
      32mm doesn't sound like a drum. Sounds more like a PCR or mag. roller. What does the manual say on the repetitive defect gauge? Can you post an example?
      • copier tech
        • 8285
        Hello community,
        Kenny (Bolton454)
        It would help if you could post some print samples. If you can't upload them the .jpg needs to be under 1mb, so resize & try again.
        However if you have white lines on the prints & have replaced the PCU the lines are most likely caused by the magenta developer unit.
        You can confirm this by separating the drum & dev units then rotate the dev unit & check the roller is evenly coated.
        • bolton454
          • Jun 2011
          • 7
          Thank you all for your responses!
          (Image's were too large so I shrunk them down to upload. Thanks for the info on that)
          I do not have the service manual for this model but I may be able to get a copy to look up the defect distances.
          The developer roller coating looks normal and smooth.
          I wonder if a developer gear is jumping? The marks are identical.
          Test sheet------and----Test Print
          Bolton
          • bolton454
            • Jun 2011
            • 7
            Developer looks ok. But suspect it may be the issue.
            Bolton
            • bolton454
              • Jun 2011
              • 7
              Thanks for your reply.
              I was thinking it was the foam roller on the pcr on the original unit.
              The new (rebuilt) unit from NA Trading made the that print defect.
              Bolton
              • bolton454
                • Jun 2011
                • 7
                Here are a couple of images.
                • copier tech
                  • 8285
                  [ATTACH=CONFIG]48045[/ATTACH][ATTACH=CONFIG]48046[/ATTACH]
                  So you rebuilt the PCU & didn’t replace it with a genuine Ricoh unit?
                  • bolton454
                    • Jun 2011
                    • 7
                    The drum is a rebuilt drum unit from NA Trading, not an OEM.
                    two different drum units are making the same print defect.
                    Bolton
                      Bolton
                      never did like NA Trading products.
                        • 16766
                        I don't understand why you don't look at the repetitive defect gauge in the manual.
                        • tsbservice
                          Field tech
                          • 8112
                          For some reason your rebuilded drum unit is bad. Replace with another better OEM, problem solved.
                          • bolton454
                            • Jun 2011
                            • 7
                            Greetings ALL,
                            Good news, I found the issue is with the developer roller. It had a horizontal line of gook that caused the developer "brush" to stick up and clump dev powder. I wiped it across with a dry paper shop towel until the roller appeared clean. I will post test prints and more details later.
                            Thank you all for your help and support in resolving this issue!
                            Kenny
                            Bolton454
                            • copier tech
                              • 8285
                              Greetings ALL,
                              Kenny
                              Bolton454
