Re: Lanier MPC3002 Magenta CQ the same after replacing drum unit
Greetings ALL,
Good news, I found the issue is with the developer roller. It had a horizontal line of gook that caused the developer "brush" to stick up and clump dev powder. I wiped it across with a dry paper shop towel until the roller appeared clean. I will post test prints and more details later.
Thank you all for your help and support in resolving this issue!
Kenny
Bolton454Leave a comment:
For some reason your rebuilded drum unit is bad. Replace with another better OEM, problem solved.Leave a comment:
I don't understand why you don't look at the repetitive defect gauge in the manual.Leave a comment:
two different drum units are making the same print defect.
BoltonLast edited by bolton454; 01-26-2021, 08:20 PM.Leave a comment:
It would help if you could post some print samples. If you can't upload them the .jpg needs to be under 1mb, so resize & try again.
However if you have white lines on the prints & have replaced the PCU the lines are most likely caused by the magenta developer unit.
You can confirm this by separating the drum & dev units then rotate the dev unit & check the roller is evenly coated.
IMG-4264Small.jpgIMG-4262Small.jpgLeave a comment:
I was thinking it was the foam roller on the pcr on the original unit.
The new (rebuilt) unit from NA Trading made the that print defect.
BoltonLeave a comment:
Thank you all for your responses!
(Image's were too large so I shrunk them down to upload. Thanks for the info on that)
I do not have the service manual for this model but I may be able to get a copy to look up the defect distances.
The developer roller coating looks normal and smooth.
I wonder if a developer gear is jumping? The marks are identical.
Test sheet------and----Test Print
Hello community,
I have Lanier MPC3002 with an issue with the magenta color. The marks are vertical and 32mm apart. I replaced the drum unit since the foam roller (10mm) damaged but the same issue occurred with a rebuilt drum unit.
The CQ lines and voiding happen when I use the scanner or the printer. Not able to load images for some reason.
Thanks for your help.
Kenny (Bolton454)
Hello community,
Thanks for your hel
Kenny (Bolton454)Leave a comment:
Hello community,
Hello community,
Kenny (Bolton454)
