IM 550 Very Light copies
  • MIKON
    • Jul 2015
    • 188
    I changed the drum and drum connector board.Still no good only 22k on machine no error codes.Any suggestions.
    Re: IM 550 Very Light copies
    are you using compatible toners?
    did you clean the laser glass?
    did you do a STOP TEST to see if the image on the belt?
    why replace boards when you didn't properly diag the problem?
    is the paper damp?
    Phil B. ' The Dentist '
    • GIUBOSS
      • 1436
      Try opening the front door while printing and checking if the correct image to be printed is on the drum surface, also check the developing roller surface if it is well impregnated with toner. A look at the electrical connections where the drum cartridge connects to the machine.
      • copier tech
        • 8172
        "Very light copies"
        How about the prints or is the issue only why copying?
        • MIKON
          • Jul 2015
          • 188
          I did stop test there is image on the drum with normal density.it appears to be a transfer issue.and it is the same with copies and prints.genuine toner and not damp paper. I replaced the drum connector board because the help desk suggested it. I am not familiar with this model I was just wondering if anyone has run into this issue on this Model.
            Well now you have narrowed the field.. concentrate on transfer...
            Roller holders cracked
            Wires disconnected
            Belt not lifting etc
            • davel
              • Oct 2011
              • 1107
              Have you ever seen an IM550 Phil?
              • copier tech
                • 8172
                I doubt it as this model doesn't have a belt!
                • skinnyb
                  • Jul 2008
                  • 291
                  Truth. Rebadged Kyocera piece of junk....
                  Sent from my LM-V405 using Tapatalk
                    • 23009
                    It looks like an ECOSYS M3540 or M3645. We haven't particularly experienced transfer issues on that model, but it's certainly possible.
                    Can you get into service mode to print an Event Log?
                    • FrohnB
                      • Jul 2017
                      • 1919
                      Have you cleaned the LED array above the drum??
                      common problem on this model. Usually one side is voided or light.
                      Do you have a sample you can upload?
                      Omertà
                      • MIKON
                        • Jul 2015
                        • 188
                        Update
                        I went back with powerpack advised by helpdesk.
                        And before i had to tear the whole machine apart to get to it.I removed the transfer roller to inspect it,and when I reinstalled it the copies were back to normal.I don't know if it was a bad electrical connection or the roller was not rotating. But it is working.
