Ricoh mpc5503 paper mismatched
  • Pixtech Frameworks
    • May 2020
    • 238
    Hello All,
    I have a customer Ricoh mpc5503 showing "paper mismatched" whenever a printing job is sent through bypass from the computer system. For example send A3 plain paper from computer system, machine says load A3 paper, after inserting A3 paper, SRA3 shows on the printer screen and doesn't print. I've tried uninstall print driver and install latest drive still the same. Is there a way out of this mess???
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Ricoh mpc5503 paper mismatched
    paper type, size and weight needs to be the same both on the pc document and printer tray paper set up.
    If not, that is the error it will show.
      • May 2020
      • 238
      Please is there a way I can make the auto detect work properly?
      • Gift
        • Mar 2011
        • 2459
        I'd bet the harness in the bypass tray is broken. Check the sensors via input check SP. Replacing it is not fun IIRC. You might be able to bypass the problem if you set the paper size manually or enable "auto-continue" in user tools -> printer -> system.
        • luca72
          • Oct 2017
          • 1790
          Originally posted by Pixtech Frameworks
          Hello All,
          you have try to set in printer setting on user tools (continue>immediately)?
          "I'll be back"
            • 37553
            I have had that with Cxx03 as well as with C4502/C5502. There is a sensor with a flag actuator that is used to determine the paper length, i.e. A4 wide edge feed not covered and A3 covered. I have had the problem be a bad sensor, a bad actuator and a broken lead in the harness going to the sensor. The sensor and the actuator are not super difficult but with the harness I suggest you replace the entire manual feed table and save some headaches.
            • copier tech
              • 8188
              Hello All,
              From the copy screen does the bypass show the correct size, in your case A3?
                • May 2020
                • 238
                No, it doesn't show the correct paper size
                  • May 2020
                  • 238
                  No, I've not.
                  • anothertech
                    • 1771
                    Go into IO mode SP5- to check the sensors in the bypass.
                    • sandmanmac
                      • 3983
                      Could it be that the printer system settings are set to Machine settings for the Bypass tray rather than Driver/ Command ?
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        +1 user tool - printer - system - auto continue - immediate
                        Regards Mark
                        • Oze
                          Ricoh Fanboy
                          • Jul 2008
                          • 1663
                          ^---------------------------That right there......that will fix it.
