Question about the Pro 8200 Fuser Unit
  • Hoosierdaddy
    • Oct 2016
    • 182
    Does anyone rebuild these? and if so what are the essential parts that you put into the rebuilt fuser. I used to get the Fuser TRCU Unit bI have ut ricoh doesnt have them anymore. But they will sell you the Fusing unit as a part for $3K I have a core to rebuild and dont want to miss any critical parts.
    Hoosierdaddy
    PS Unless someone knows of a source to get them rebuilt
  • Notrons
    • Apr 2016
    • 71
    Re: Question about the Pro 8200 Fuser Unit
    Hoosierdaddy
    Here you go, straight from the PSG. Try Prescision Rollor or just goggle the parts #
    D1794197 Flat Belt Fusing Dia80:Seal
    AE010118 Hot RollerIA54: Ass’y
    AE020220 Pressure Roller: DIA65
    AE030049 Ball Bearing-20x32x7
    • anothertech
      • 1771
      Your going to need more parts than that.
        • 37533
        That is all for the 1000K maintenance. The web should be replaced ever 600K and most likely will not make 1000K. The hot roller is actually specified at 1800K but it is easier to replace it when you have the fusing unit apart at 1000K than to try to go 2000K.
        • JaysOnTheEDGE
          • 61
          I replace the AE030086 bearings as well as the above mentioned parts there are 4 ( 2 for pressure, 2 for heat roller) and the heat roller bushings as needed. Usually every other rebuild or as needed. (they will swell up)
          Also the Hot roller on the 8200 is AE01-0130; the AE01-0118 is for the 8100 I have always had good luck replacing all the bearings every time.
          I can do one of these fusers in about 45 minutes now but I've done close to a 100 of them lol. I usually have to go back and fix the mistakes of the guy who did it before me and used the wrong parts or didn't replace the bearings and they froze up up taking out the belt throwing the SC520 for fuser motor lock.
          • anothertech
            • 1771
            I let the fusers run for 2 million just changing the web along the way. By 2 mil the ball bearings are starting to fall out of them landing in the tray under the fuser but the machines are still chugging away like nothings wrong.
            • copier tech
              • 8174
              45 mins that is impressive!
              • Hoosierdaddy
                • Oct 2016
                • 182
                Thanks for the heads up, I was going to replace those parts also. Do you replace the gears on the rear of the fuser also?
                • Notrons
                  • Apr 2016
                  • 71
                  No, not unless there need to. I normally just do a clean/inspect and replace as needed.
                  • JaysOnTheEDGE
                    • 61
                    i only replace the gears when they become excessively worn or get damaged. They do require periodic lubrication though i think the manual states every 600K to put some grease on them.
                    • Hoosierdaddy
                      • Oct 2016
                      • 182
                      OK Thanks Job Done
                      • butcher
                        • 48
                        The Gears do go after half a dozen or so rebuilds.It's important to put new grease onto those gears at every rebuild.This will help them live longer
