any guide list for slow printing non WSD?
  • fshead
    • 2376
    HI
    I have a ricoh sp5200 b/w copier that is hooked up configure the manual way,IP address not WSD and tried using pcl 6 and pcl 5 driver but still seems slow
    printing PDF docs.When logging on to machine via WIM it seemed to be slow to load page and respond.
    Any thoughts,any setting via service mode to change/check?
    thanks
  • jhalfhide
    • Apr 2015
    • 454
    Re: any guide list for slow printing non WSD?
    Have you got your ethernet port speed settings right? Have you tested with a laptop straight into the device?
    Sent from my LYA-L09 using Tapatalk
    • KeviM
      • Oct 2019
      • 324
      I've experienced a similar sort of problem with a Ricoh MP2550 at 1 of our engineering clients. Machine took ages to print even small documents.
      We eventually brought the machine into the workshop for testing. What I found is that the machine worked perfectly in the workshop with our computer and network, even with some very large PDF engineering documents.
      So the fault in my situation resided in the clients slow network and computers. I would recommend the same as the other technician mentioned, take your own laptop and cable and test directly.
      • TonerMunkeh
        Professional Moron
        • 3865
        Use "print as image" in the advanced tab of the print dialog box. PDF printing is a pain in the arse.
        Hit it.
        • tsbservice
          Field tech
          • 8020
          So you took back whole machine to workshop instead of bringing laptop to customer's site?
          Direct printing to the machine with their files should be way more easy to eliminate client network and PCs
          • copier tech
            • 8174
            Originally posted by fshead
            HI
            thanks
            Hook a laptop up direct if print speed is still the same update the firmware.
              • 37533
              Check the graphics setting in Printing Defaults - Print Quality. I had a church that was trying to print their bulletin for Sunday's service. It was taking about 30 minutes to queue a 11X17 page. I can't remember if I changed it from Raster to Vector or the other way around but after changing the setting it only took 30 seconds a page. Depending on the type of images one will work faster than the other.
              • romang
                • Aug 2011
                • 72
                • fshead
                  • 2376
                  hi
                  no i have not gone with my laptop but will with a 5 port splitter and see how it prints from my laptop.
                  I also feel it seems the response from her PC is super slow as is her PC with 20 programs not needed but open..accountant office
                  • fshead
                    • 2376
                    THANKS for the fast responses...
                    what i did notice is they were trying to print a pdf from email attachment and that seemed to go slow..
                    Aldo it seemed to stop between every page..They also have that dabn dreaded MCAFEE VIRUS BUNDLE which always gave me pains with scanning..
                    AS I have been doing everything but copier repair over the last 11 months I am already forgetting things i remember...
                    • KeviM
                      • Oct 2019
                      • 324
                      Lol.. I should have given you guys more details. The machine first had the problem with the slow printing. Then after a while developed other issues, that's why we decided to bring it in.
                      • D_L_P
                        Self Employed
                        • Oct 2009
                        • 1196
                        Originally posted by fshead;169003%
                        ..WIM it seemed to be slow to load page and respond.
                        Replace the HDD
                        Slow print & slow web is typically a HDD on its way out. A format may bring new life back into it for a few weeks but the sluggishness will return.
                        If I remember correctly, the HDD can be disabled and printing still works. But some print features are disabled too.
                        • Mark Bbb
                          • Jun 2012
                          • 1662
                          Also, install and select Adobe reader if they use another PDF software.
                          • luca72
                            • Oct 2017
                            • 1784
                            HI
                            thanks
                            Hi, I have solved in the past in one of the following ways:
                            1) delete the ip port, and recreate it, maybe corrupted
                            2) delete the driver libraries from the windows administration tools, reinstall the printer with a newer driver
                            3) reinstall / update acrobat
                            "I'll be back"
                            • tsbservice
                              Field tech
                              • 8020
                              HI
                              thanks
                              May worth try another PDF viewer, for example Foxit Reader:
                              Free PDF Reader & PDF Viewer Download | Foxit Software
