mpc5502 fuser set clicking
  • digicor
    • Jul 2008
    • 1159
    i thought there was a firmware update for the "clicking" the fuser makes when its setting in place on startup.. I have the latest FW so i thought..
    is there another fix? or i just dont have the latest FW for the machine,
    if i dont does someone have it? i can get it from,
    thanks
  • DRichard
    • May 2008
    • 482
    Re: mpc5502 fuser set clicking
    thanks
    Lube the bearings with high-temp grease.
    "Enjoy every sandwich."
    -- Warren Zevon
    • copier tech
      • 8174
      thanks
      Is it a loud 3x clicking sound like gears slipping? if so as you say update the firmware then set the fuser pressure timing with SP1151-004 to 800.
        • 37533
        In addition to the firmware update there was also a change in the fusing sleeve.
        rfg056541.pdf
        There was also a problem with the pressure roller gear causing a clicking noise. May need to replace the gear with newer style.
        rfg055949.pdf
        • digicor
          • Jul 2008
          • 1159
          okay some how the 1151-800 was up above 25oo ms..? how did this occure? or did a previous tech set it there?
          the default is 550... i set it to 800.... whalah.. no clicking
          Thanks guys
          • copier tech
            • 8174
            Thanks guys
