Printer options not available in 3503/6003
  • AjitN
    • Mar 2009
    • 287
    [Misc] Printer options not available in 3503/6003
    I got few rebuild MPC machines 6003/3503/3504/6004.
    In this machines printer option is not available at all.
    Even if I go to ACC screen only copy option is displayed.
    Any setting required in SP mode? OR is firmware update required.
    Please suggest
    Regards & thanks
  • copier tech
    • 8174
    Re: Printer options not available in 3503/6003
    Please suggest
    Regards & thanks
    Most likely these machines have had a fiery installed, remove the additional LAN card if it has one.
    Then you need to set a SP modes to enable the GW controller printing using SP5985 to 0 (external controller not installed)
    • GIUBOSS
      • 1436
      Please suggest
      Regards & thanks
      If I'm not mistaken it could be an application to add to the home screen, have you tried to install them on the network or with usb?
      • GIUBOSS
        • 1436
        Please suggest
        Regards & thanks
        SP 5985
        [Device Setting]
        NIC (Network) and USB capabilities are built into the GW controller. Use this SP
        to enable / disable these features. In order to use the NIC and USB functions
        integrated into the controller board, set these SPs to "1".
        • fshead
          • 2376
          Shouldnt you ask who you bought these from??????????????????
          • anothertech
            • 1771
            Is it possible the hard drives have been removed?
            • copier tech
              • 8174
              With a HDD missing on a Ricoh it will still print.
              • AjitN
                • Mar 2009
                • 287
                Please suggest
                Regards & thanks
                Machine doesn't enter in to SP mode at all, done factory reset also, 806182 + C doesn't work at all.
                Please suggest, Regards
                • copier tech
                  • 8174
                  How did you perform a 'factory reset' if you can't enter SP mode?
                    That doesn't make sense. How did you perform reset without getting into service mode?
                    • copier tech
                      • 8174
                      Thats exactly what I said immediately above your comment!
                        sorry dude.. guess I should read all the posts before replying ....
                        still waiting on the OP's reply tho.
                        • copier tech
                          • 8174
                          No worries.
                          I guess if he can't log in with to the regular SP he always has the factory SP mode to use.
