Ricoh C3500a printer - No memory available at heap & stack size
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh C3500a printer - No memory available at heap & stack size
    Originally posted by Debs1964
    Is it an MP C3500 or IM C3500?
    Debs the genius.
    Hit it.
    • anothertech
      • 1769
      Most solutions now run on the SOP and don't require the optional Java card, you'll likely only need to purchase Java cards if the solution you're running is an old version
      Yeah, I figured that out when I replaced a SOP and then my Streamline didn't work anymore.
      • Debs1964
        • Oct 2010
        • 1693
        Originally posted by TonerMunkeh
        Debs the genius.
        There are 10 types of people in this world, those who understand binary maths and those who don't
        • jordy144
          • Mar 2021
          • 7
          #19
          We have finally received the printers, and also purchased the VM Card Type M37 cards.
          I'm stuck at this point: Installation Procedure
          The printer isn't to anything when I'm inserting the card into the slots, also won't find any installation on the cards. Is there anything I'm doing wrong? Or does these cards needs to be installed first? I thought they are already installed. Also memory is upgraded from 2GB to 4GB.
          Hope anyone can help me further with this. Thanks in advance.
          • TonerMunkeh
            Professional Moron
            • 3865
            #20
            Check SP5730 and see if the Java is switched on. You should then see Extended Features in User Tools.
            Hit it.
              • 37490
              #21
              Your "Installation Procedure" is missing a very important step, the first one. Any insertion or removal of an SD card into either of the service slots must be done with the power OFF. Failure to do can destroy the SD Card and in the case of the VM card will also damage the controller PCB.
