Gestetner aficio MP 2000
  • Gab
    • Aug 2015
    • 676
    Where i can find printer drivers forwin 10 for this model. I downloaded from Ricoh site drivers but it doesn;t work.,
  • Mark Bbb
    • Jun 2012
    • 1662
    Re: Gestetner aficio MP 2000
    you must experiment with drivers from other models, mp2851 perhaps.
    • GIUBOSS
      • 1437
      the drivers for w10 are there and they work, if you do not have problems with w10 updates or network port etc.
      • copier tech
        • 8212
        Aficio MP 2000 Downloads | Ricoh Global
        Click Here To Download - Ricoh, Konica Minolta, Kyocera, Lexmark or Canon Firmware
          • 37618
          Do you have the aficio MP 2000, aficio MP 2000L or aficio MP 2000L2. The supported drivers are different. The 2000L NS 2000L2 are DDST printers and only work with DDST drivers or in the case of the 2000L, PCL drivers for DDST.
          2000L drivers Aficio MP 1600/1600L/2000/2000L(DDST) Downloads | Ricoh Global
          2000L2 drivers Aficio MP1600L2/2000LN2 Downloads | Ricoh Global
          • anothertech
            • 1771
            Looks like the base model MP 2000 is copier only unless it has the Printer/Scanner unit or the Print/Scan/Fax kit.
            • Gab
              • Aug 2015
              • 676
              ok thanks it works with ddsd drivers .
              Can anybody introduce to me some good free scaner programs
              • GIUBOSS
                • 1437
                Winscan2pdf
                  can't you do a web search on your own?
                  the word is SCANNER programs .. maybe learn how to spell it'll do wonders in your searches .
                    • 37618
                    Phil, it's Gab, he doesn't know how to do anything by himself thus all the RED cards.
                    • anothertech
                      • 1771
                      I've always wondered, how do I give a red card?
                        • 37618
                        The little star shaped icon at the bottom left corner.
                          My bad brother
                          • Gab
                            • Aug 2015
                            • 676
                            when i say a scaner program i mean a good scaner program that somebody worked with this. Of course i can find in internet scaner programs but i want a good one that works fine with nths copier (2000L) . Also i tried to install DDST scaner twain drivers but had problems . After installation appears in attached file.Noscaner to select and when i select discover error appears. Any suggestion how to choose scaner ?
                            • sandmanmac
                              • 3990
                              No....but I'm 'lowering the shields' on my ignore list very briefly because as previously mentioned, I find it very intriguing at your near perfect spelling and grammar - except for the word "scanner", and it's even shown multiple times on your sample pics (just an observation) .
                              Shields back up!
