Ricoh MP c6502
  • tcypy1961
    • 773
    Ricoh MP c6502
    I don't service these copiers enough to warrant getting a manual. So I had this question: Can the front door of this copier only be opened when in error mode? I have attempted to open it without success, and I am wondering if there is something I am missing that will allow me access.
    An additional question, is the SP access code 806182, and is this where I'd find where to open the door? If it is where I find, what would the code be?
    Thank you for any help provided.
    • 37422
    Re: Ricoh MP c6502
    Anyone who attempts to work on a Production or high volume model without a manual is asking for nothing but headaches. It costs absolutely nothing to place a request for a service manual in the Service Manuals Requests forum. Most other techs here are more than happy to provide one free of charge when you do.
      Re: Ricoh MP c6502
      +1 on all of this statement
      • luca72
        • Oct 2017
        • 1759
        Re: Ricoh MP c6502
        we don't have that model around, so I don't know it, but I deduce that if the door doesn't open, it means that some parts are not in hp, and the draft cannot scroll out, I think in sp "output check" or other sp, there is one
        some sort of mechanism free run routine to release or test the draft lock, maybe you need to have other background information, for example, in some model, spinning the fuser sleeve without opening the waste toner box door, can destroy it...just to name one
        "I'll be back"
        • bojans
          • 1313
          Re: Ricoh MP c6502
          You should be able to open front door in ready state and when powered off. Maybe something is blocking opening. As fas as i remember when you "pull handle" machine "unlocks" door in couple seconds and you can slide it out.
          I have only two in the field, with just few service calls, changing pcu cleaning, so not too familiar with problems.
          • copier tech
            • 8133
            Re: Ricoh MP c6502
            As others have said if you are not trained on this model best not to touch it especially without the service manual.
            This model has a locking system to prevent you from opening the front draw while the transfer is engaged to prevent damage.
            Shut down the machine the draw should unlock itself unless you have an error related to this area.
            Service mode is the same as other Ricoh models.
              • 37422
              Re: Ricoh MP c6502
              Could be he just doesn't know where the release for the drawer is located. It's in the users manual that Ricoh makes available for free on their public public page.
              • anothertech
                • 1766
                Re: Ricoh MP c6502
                If you have a jam, you need to open the finisher door and the LCT doors first before the main drawer will unlock.
                • JaysOnTheEDGE
                  • 61
                  Re: Ricoh MP c6502
                  Whatever you do don't try to force the door open you can break or bend the rotating cam pin that locks the door and then it will really be stuck there is a procedure in the manual that allows you do manually unlock it if needed puts its pretty involved process. requiring major disassembly.
                  • tcypy1961
                    • 773
                    Re: Ricoh MP c6502
                    Thanks; I would hope the fact that I've been in the business since 1984 would count for something instead of being made to feel like an idiot. The customer who has the machines runs a print shop and with experience only on printing presses does most the service himself. I just try to learn the machine as I go using my knowledge from other copiers and picking the brains from other techs. I just found it interesting that the door could only be opened in error mode and figured there had to be another way to open door. I will not attempt any repair without getting info. About the only thing I have use for a manual is error codes and SP modes. I appreciate what HELP is offered.
                    • mga
                      Copier Technician
                      • Dec 2010
                      • 1393
                      Re: Ricoh MP c6502
                      Call a credited ricoh trained engineer if the front draw is locked in it can only be opened manually there is a technical bulletin about this had it a few times before. Do you know what the error is
                      Regards Mark
                      • mga
                        Copier Technician
                        • Dec 2010
                        • 1393
                        Re: Ricoh MP c6502
                        Try this hope it will help
                        Regards Mark
                        • FrohnB
                          • Jul 2017
                          • 1919
                          Re: Ricoh MP c6502
                          Do you have an SC 525 by chance?
                          These machines have a bulletin for the lock mechanism breaking with a corresponding SC525-01 code.
                          But I believe you’re still able to open the drawer in that scenario.
                          i know there’s another bulletin for not being able to open the drawer unit, but can’t seem to locate it. Maybe someone on here can assist with that? TSRC is limiting what I can search for on my phone!
                          EDIT: mga beat me to it!
                          Omertà
                          • copytech,mike
                            CopyTech,MIKE
                            • Jun 2014
                            • 261
                            Re: Ricoh MP c6502
                            I have that code and it seems to be a really nasty problem. This drawer is locked!
                              • 37422
                              Re: Ricoh MP c6502
                              Would you fucking stop grave robbing. Start a new thread idiot.
