mp4002 dirty egde, only lateraly
  • luca72
    • Oct 2017
    • 1775
    hello everyone, I have this problem on an 870k bk mp4002, practically dirty the sheets, not in front, where there is the print, but sideways, the problem can only be seen by looking at the stack of paper from the side, it does it in the lower side .
    i already went out 3 times, i replaced opc, blade, ccroller, c.roller, developer, transfer belt, transfer blade, cleaned everything perfectly, development unit and developer, they are new 10k bk, comes from another machine we threw away
    "I'll be back"
  • GIUBOSS
    • 1433
    Re: mp4002 dirty egde, only lateraly
    what do you think of the fuser unit and web roller etc.
    • luca72
      • Oct 2017
      • 1775
      hello, the problem is on the pcdu, there seems to be a part that does not clean up, the fuser I replaced it 10 days ago for another problem, today I replaced the developer, despite only having 11k the one in the car, and the cleaning blade , I moved the drawer straps a couple of millimeters, the customer called back after two hours, I put the photos, the customer printed 5k prints in one night
      "I'll be back"
      • Gift
        • Mar 2011
        • 2459
        Bad drum shaft grounding can also increase this issue. How does the dv mag roller looks like? IIRC it kind of became coated black with toner and needed to be cleaned after 60-80k. Since you have to repeat this pretty often over time it's also possible that the DV gap might've shifted - can't recall he optmum setting but I kow that I put 2 or 3 sheets of 80g paper between the doctor blade and mag roller as refererence.
        All in all this is was a shit piece of a print engine back in 2008 around - plan a is getting the customer convinced to swap it, just tell them you can't get all neccessary parts to fix this issue since parts support discontinued.
        • GIUBOSS
          • 1433
          with the high number of copies made, it may be that the toner collection section (behind the cleaning blade) has fluff that obstructs the passage of the used toner and rejects it before it goes down into the developer unit
          • luca72
            • Oct 2017
            • 1775
            hello, the developer unit is new, almost out of the box, I got it from another machine that we threw away, which had been replaced a few months ago, the magnetic roller was bright, but I cleaned it anyway, the developer is new, changed today
            I am also attaching a third photo of the defect, it didn't fit before, probably due to size problems
            "I'll be back"
            • luca72
              • Oct 2017
              • 1775
              the exhaust is super clean, looked from side to side, and pulled out the spring,
              I can't attach the third photo, too big, however dirty at the bottom of the page
              "I'll be back"
              • copytrust
                • Feb 2010
                • 118
                it seems like a transfer unit issue, not sure about that thought, maybe if you have anoother transfer unit from another machine you can try it......
                • GIUBOSS
                  • 1433
                  check the copper bearings of the charge roller if worn. Have you already tried with the other whole drum unit?
                  • MIGUELMARCHENA
                    • Feb 2018
                    • 192
                    In image 2, it appears that there is developer added to the cylinder
                    Are the load and bias values ​​standard?
                    is the mylar of the cylinder unit ok? or is the acetate loose?
                    • luca72
                      • Oct 2017
                      • 1775
                      hi, I also thought, in fact I cleaned and rebuilt it the day before, together with the cleaning of the pcdu components
                      "I'll be back"
                      • luca72
                        • Oct 2017
                        • 1775
                        hello, I disassemble those bushings and always clean them with a screwdriver, alcohol and rag, but to do it first, that day of the first intervention, I replaced the pcdu with that of another machine we threw away, with the consumables recently replaced, I'm getting the doubt that since it was an mp4001 maybe it has an outdated frame, because the old ones lacked a contact, however on Monday afternoon we replace it with another mp4002 that I have here ready, we after the third time we go out for the same thing, we substitute the complete machine, for company policy, obviously as long as we are not talking about a martini
                        "I'll be back"
                          • 37481
                          2a-1.pdf looks exactly like one with a partially clogged toner recycle unit.
                          • mga
                            Copier Technician
                            • Dec 2010
                            • 1393
                            Replace with new parts these machines have mag roller problems always need cleaning when replacing developer make sure mag roller is silver. And set up correctly
                            Regards Mark
                            • mga
                              Copier Technician
                              • Dec 2010
                              • 1393
                              When you swapping from other machines are you re setting up or are you just fitting then leaving if so there's your problems save time and money just rebuild correctly with new parts
                              Regards Mark
