MP 6001SP WEB MOTOR
  • Polo-022
    • Sep 2007
    • 486
    MP 6001SP WEB MOTOR
    I have a web motor running continuously, since i switch on the machine.
    Harness has been checked and it is not grounded somewhere, so i think
    it is the BICU failed. Does anyone came across this failure?
    By the way, i would like to ask where are the Schematics, part of Service
    Manual located? I am having access to My Ricoh site but i cannot find it, nowhere!!
    Thans in advance for any help...
  • anothertech
    • 1769
    Re: MP 6001SP WEB MOTOR
    The Schematic is located in the Point to Point diagram.
    • Polo-022
      • Sep 2007
      • 486
      Oh!!! This is obvious!!
      Should i have to change my question : Where is P2P diagram located...??
        • 37490
        the point to point will give you connection information between boards and major components. If you want schematics for the boards you will need to become an authorized board repair facility.
        • Polo-022
          • Sep 2007
          • 486
          I didn't ask for boards wiring diagram!!!
          • Polo-022
            • Sep 2007
            • 486
            "I have a web motor running continuously, since i switch on the machine.
            it is the BICU failed. Does anyone came across this failure?"
            This is the first part!!!
              • 37490
              You asked for schematics. That means board level wiring. The Point to Point is a separate document. RFG E-source number in the US is 039081. Check the PSG for your region to see if they list the order number for your area. Try on the last page. If you cannot find a source, put a request in the Service Manual Request Forum.
                that too is located in the service manual
                  maybe you didn't state your needs clearly enough.
                    • 37490
                    Separate manual.
                    • GIUBOSS
                      • 1435
                      Have you tried updating the firmware?
                      • anothertech
                        • 1769
                        Page 1.pdf
                        Motor M13
                        section F4
                        Wires go to BCU CN203 pins B1 and B2
                        Is there anything else?
                          • 37490
                          [ATTACH]49024[/ATTACH]
                          Motor M13
                          section F4
                          That's show what I was thinking. Leakage to ground anywhere from the motor all the way back to CN203 B2 will cause the problem. Check where the harness from the web unit passes across the bottom of the fusing unit. If it is making contact with the top of a hex head screw it can leak there but the damage might not show on visual inspection. I have had it happen to the leads going to the web end switch and cause a false web end message less than 24 hours after replacing the web. double sided tape and a pice of rubber cut from an old inner tube corrects the problem.
                            +1
                            Good MacGyver
                            • anothertech
                              • 1769
                              Bulletin about the web motor.
                              New Style Web Motor.pdf
