Ricoh MPC6503 (Charis) - Jam code 025
  • Batman1976
    • Jun 2016
    • 91
    [Jamming] Ricoh MPC6503 (Charis) - Jam code 025
    Hi Chaps,
    We have an MPC6503 with intermittent jams at fuser exit/inverter sensor - Jam code 025.
    Fuser has been rebuilt with all parts replaced. Sensors cleaned etc etc. Paper seems to stop and concertina up after fuser and before inverter.
    Anyone other ideas welcome......
    Batman76
  • GIUBOSS
    • 1436
    Re: Ricoh MPC6503 (Charis) - Jam code 025
    Originally posted by Batman1976
    Hi Chaps,
    Batman76
    was the previous replacement problem the same? Original replacements? duplex, any size / paper tray?
    • Batman1976
      • Jun 2016
      • 91
      All original OEM Parts replaced. Mainly A4 from any tray.
      In saying this I've just run over 500 sheets through and ZERO jams. I'm gonna run with it and keep an eye on Jam history.
        • 37532
        Are you sure the jam code is 025, not listed in the service manual, and not 015 Exit Unit Entrance SN: Late?
        Check the lower fusing guide plate and the plastic entrance guides for the exit section for warping, burrs and broken fingers. I have had to replace them in the past for jams in that area. I have also had the exit entrance sensor go flaky due to the heat from the fusing unit. The entrance and exit sensors for the exit are the same and can be swapped to see if that corrects the problem.
        • TonerMunkeh
          Professional Moron
          • 3865
          What sort of mileage is this thing on? The exit units start to get a bit tired around the 1.5m mark.
          Hit it.
          • MIKON
            • Jul 2015
            • 188
            Check the foam rollers in the exit unit....
            • mga
              Copier Technician
              • Dec 2010
              • 1393
              Hi Chaps,
              Batman76
              If intermittent jam could be exit sensor starting to go down try swapping with paper transport sensor
              Regards Mark
              • StephenB
                • Aug 2015
                • 244
                Look closely at the exit assembly, just past the fuser....the guide actually warps from exit roller tension / pressure.
                I ran around in circles to find the problem, very intermittent jams.
                Good luck !
                • Batman1976
                  • Jun 2016
                  • 91
                  Hi Chaos,
                  This turned out to be a slighty broken blue connector block on right rear side of the main draw unit. This was causing a loose connection of the cable and resulting in intermitten Jams at fuser exit (Code 25). Connector blocks replaced and wiring cable reconnected.
                  All sorted
                  • GIUBOSS
                    • 1436
                    Hi Chaos,
                    All sorted
                    sometimes with haste or with little attention this also happens ... thanks for updating us.
                    • anothertech
                      • 1771
                      Hi Chaos,
                      All sorted
                      What are the part numbers you had to replace?
                      • Batman1976
                        • Jun 2016
                        • 91
                        Originally posted by anothertech
                        what are the part numbers you had to replace?
                        11035841 (connector:28w0r-rfc-egd(lf)(sn))
                        11035840 (connector:rfcp-28w0-e)
                        11035760 (connector:36w0r-rfc-egd(lf)(sn))
                        11035758 (connector:rfcp-36w0-e)
