MPC307 SC102
  • GeorgeBest
    • Jul 2009
    • 526
    MPC307 SC102
    Hi
    this C307 is given an SC102 after printing out the counter . .
    before that I had to replace the toner ID sensor board because one of the toners did not recognized
    Hell of a job, but eventually it worked, I thought, now getting this SC102 !!
    Copy lamp is blinking, checked the connectors over and over again . . .
    Anyone, help is appreciated
    gr George
  • dalewb74
    • Feb 2018
    • 1153
    what have you do so far to fix it? firmware? re-checked all your connections while replacing the ID sensor? if it occurred after you replaced the sensor then the problem is the........
    • GeorgeBest
      • Jul 2009
      • 526
      I have re checked all my connection yes, strange that the first print after replacing the ID board was good, and then immediately it went to SC102. .
      Firmware not updated, can do that . . .
      • luca72
        • Oct 2017
        • 1778
        Originally posted by GeorgeBest
        Hi
        gr George
        try starting from the simplest things:
        1) upgrade the firmware
        2) reseat the flat-cables
        3) *try to clean well the led array and the little ccd mirrors hiddens in the carriage, the disassembly to get there is a bit boring, but it can also be done easily by the customer.
        *the dirty mirrors, can lower the brightness of the array-led, generating the sc error
        "I'll be back"
          • 37488
          First thing I would do is get out my service manual and go to the trouble shooting for SC102-00 LED intensity adjustment error.
          • dalewb74
            • Feb 2018
            • 1153
            yeah that's exactly what i saw when i looked at my service manual as well. when i looked it up, i was looking for a sc102-xx. because usually it has a couple more digits on the end. but i only saw the 102-00 so i went with that.
            • GeorgeBest
              • Jul 2009
              • 526
              rechecked all connectors and FC, especially from the scanner assembley, it worked eventually, so probably there was a bad connection somewhere....
              Thanks for the reply's !
              gr G
