MP 9001 browse network error
  • sandmanmac
    • 3981
    #16
    Re: MP 9001 browse network error
    It might be the 2 that work have newer firmware.
    Unless I missed it, he's not told us what the models are, but I'm just assuming that they're different/ newer units
    • rthonpm
      • Aug 2007
      • 2859
      #17
      Production firmware for this model doesn't support anything beyond SMB1. Not sure if there was a custom firmware module for this model, but generally only the xxx2 series machines were upgraded for SMB2/3 support. The only machine from the same era I've seen updated for SMB2/3 was the MP 171.
      • anothertech
        • 1771
        #18
        There is custom firmware for this model in the US to fix this problem, but I don't know if there is custom firmware for this techs location(Spain)
        • sandmanmac
          • 3981
          #19
          Hmmm.....Seems we might be on to something here
            • 37524
            #20
            Custom firmware developed for the US market will work in machine in Europe. It is just that Ricoh-EU won't tell you about them. If you are an EU tech, you have to get them from a North America tech.
            • Gift
              • Mar 2011
              • 2459
              #21
              I guess not, afaik Ricoh Europe doesn't release them. A few years ago I was tempted to ask around for firmware in order to restore SMB function for many units out in the field. Finally I didn't asked because that would have undermined the work of our sales people^^
              Customer can always enable old SMB versions on their end if they prefer to stick with a decade years old MFP...
              • keithxxiii
                Just a tech
                • Nov 2014
                • 469
                #22
                Open telnet, check SMB client auth level on both machines.
                Make sure the setting is the same as the working machine.
                Aye! Cut the crap
                • satins
                  • Feb 2021
                  • 89
                  #23
                  Originally posted by pakobernal
                  Good morning, then, why in other ricoh machines, I can see the workgroups and the compunters? and navigate through the differents pc and when selecting one, it ask me for usernamen and password, I can't do it here.
                  It seems that you are trying to upgrade/connect on the windows network. All networks are not same as they are managed by the administrator and they can set policies depending upon their company's standard requirement and hence the network firewall does not allow the device to connect unless the policies are changed. Sometimes, O.S upgrades are also the enhanced with firewall security with similar results.
                  • pakobernal
                    • May 2012
                    • 46
                    #24
                    How? Can you explay the procedure to me?
