ricoh mpc 4504 ex 312-01
  • mrgene
    • 53
    the machine only codes when doing two sided black and white works fine on two side color and will run black and white all day long single sided. I have replaced the black pcu (twice) and also replaced the transfer belt, and did a firmware update. Any clue ???
  • copier tech
    • 8144
    Since you replaced the K PCU maybe an issue with the HV or IOB.
    • [B]
    • luca72
      • Oct 2017
      • 1778
      try if this is your case.
      "I'll be back"
        • 37490
        The only difference that I can think of would be vibration from the duplex unit affecting a loose connection to the K high voltage.
